Tire Wear
  • Thread starter Larry & Nancy Solheim
  • Start date
L
I'm seeing a bit of excessive wear on the OUTER edges of my DiamaondBack Classic radials. Too expensive to replace prematurely. Not feathering, so I know it's not balance. Toe-in is OK and would show over the whole tread, right? There's not much else to adjust. Any ideas? Thanks. Enjoying the sun SE of Tucson --Larry
<hr size="1">Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
Larry -
It's your STUB AXLE BOLT INCLINATION adjustment or your CAMBER
adjustment.
See page 5/15 thru 5/17 of the Maintenance manual for adjustment
proceedures. You are correct, Toe-in should show (in most cases)
across whole tread.
John Bevins
Any ideas?
> --Larry
rates.
WB6WSN
RE: Re: Tire Wear
<table>
<div class="OutlookMessageHeader" lang="en-us" dir="ltr" align="left"><font face="Tahoma" size="2">From: amphicar-lovers@yahoogroups.com [mailto:amphicar-lovers@yahoogroups.com] On Behalf Of a_colo_native
Sent: Sunday, April 16, 2006 9:27 PM
Subject: [amphicar-lovers] Re: Tire Wear
</font>
<tt>Larry -
adjustment.
across whole tread.
John Bevins
Any ideas?
> --Larry<span class="312161308-17042006"><font face="Century Schoolbook" color="#ff0000" size="4"></font></span></tt>
<tt><span class="312161308-17042006"></span></tt></blockquote>
<tt><span class="312161308-17042006"><font color="#0000ff"><font face="Century Schoolbook" size="4">I thought that camber was fixed by the angle of the kingpin</font><font face="Century Schoolbook" size="4">versus the stub axle. This angle was set at the factory when the kingpin hole was machined through the stub axle assembly.</font></font></span></tt>
<tt><span class="312161308-17042006"><font face="Century Schoolbook" color="#0000ff" size="4"></font></span></tt>
<tt><span class="312161308-17042006"><font face="Century Schoolbook" color="#0000ff" size="4">I didn't think there was any way that camber could be adjusted. I looked at the pages in the Maintenance Manual that you referenced, but I still don't see how to adjust camber. What am I missing? Could you be saying that part 5-21-31, the thrust bearing, is used to adjust camber?</font></span></tt>
<tt><span class="312161308-17042006"><font face="Century Schoolbook" color="#ff0000" size="4"></font></span></tt>
<div align="left"><font color="#0000ff" size="4"></font><font face="Century Schoolbook" color="#ff0000" size="4"></font></span></tt>
L
Re: Re: Tire Wear
I didn't see anything there about changing the stub axle inclination either, John.
a_colo_native <rma@amphicar.com> wrote: <blockquote class="replbq" style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"><tt>Larry -
adjustment.
across whole tread.
John Bevins
Any ideas?
Tucson
> --Larry
rates.
</tt></blockquote>
<hr size="1">Blab-away for as little as 1?/min. Make PC-to-Phone Calls using Yahoo! Messenger with Voice.
L Tire Wear Report General Amphicar Discussion 0
Jon March Trivia! - name that tire General Amphicar Discussion 0
E tire psi? General Amphicar Discussion 6
W RV tire covers General Amphicar Discussion 0
R Tire Suggestions? General Amphicar Discussion 28
D Tire options for Amphicar. General Amphicar Discussion 7
M Orig. Tire Advertisement General Amphicar Discussion 0
M Radial tire pressures General Amphicar Discussion 1
J Looking for a Tire General Amphicar Discussion 0
E Radial Tire Inner Tubes General Amphicar Discussion 0
M Spare tire cover General Amphicar Discussion 1
E Tire Size Calculator General Amphicar Discussion 0
D Rear Tire Sticking General Amphicar Discussion 0
W Tire straps General Amphicar Discussion 5
M Radial Tire Air Pressure. Front vs. rear. General Amphicar Discussion 1
R Tire Source? General Amphicar Discussion 2
D tire pressure General Amphicar Discussion 6
Z tire pressure and fuel gauge . General Amphicar Discussion 1
B front tire rub - pt. 2 General Amphicar Discussion 0
B front tire rub General Amphicar Discussion 0
C Colors and an original spare tire trade General Amphicar Discussion 0
