three holes on the body by the door
  • Thread starter Thread starter David Chapman
They allow the water that comes past the door seal or down past the window seal
to drain into the bilge without coming into the car and causing alarm.
If you suspect a door seal is leaking then cover them up with tape and if it is
you will see it come over the bottom of the door opening.
Should there be corresponding holes in the bottoms of the doors?
JB
