Mike Israel
Hi all,
Amphi is just about together but still throwing me
some curves along the way.
My latest is what appears to be no power to the
starter. Any thoughts on diagnosing or fixing would
be appreciated.
I turn the key, hit the bilge blower override and get
the red light on my cluster gauge. I turn the key and
get a nice strong "click" sound from the voltage
regulator. That is all.
I thought maybe the starter was bad so I pulled that
and just got it back from the rebuild shop. (It was
pretty cruddy inside and they did a very nice job for
$45). Anyway, I put it back in, and no change. Also
nothing if I push the starter button in the engine
compartment.
Not sure if I attached to the right spots but I took
the ends of a voltmeter and placed one on the
electrical lead to the starter and another on the
engine block. Again, I get the click from the
regulator but no power showing at the starter?
If the starter button in the engine compartment were
bad would it still start with the key? Which wires or
connections should I probe with the voltmeter.
Note that I did replace the voltage regulator over the
winter. I think I had started her since then but can
not be 100% certain. I swapped one wire at a time so I
think it is all hooked up correctly.
Thanks for any ideas.
Mike I.
be appreciated.
compartment.
Mike I.
