Theromastat
  • Thread starter Thread starter don ross
don ross
My amphi runs hot after I installed A
Spitfire , so I leave out the thermostat,
any problem there???
Bit more about the thermostat.
Problem without one there is too much flow goes to radiator and not enough through engine block. For racers Triumph sold a "Thermostat replacement plate". This was a blank steel pressing with a hole in the middle that has the same resistance to water as a fully open 'stat. However this is only really approprate for racing, the racers know the cars will overheat after say 15 minutes of use (because of the way they are tuned) so they prefer the longer warmup time you get with the 'stat fully open all the time.
The original Amphicar style "bellows" stat when it failed would close which would cause overheating so removing the stat was a roadside fix to get you home. Later type stats failed open which helped fix the problem.
The overheating problem will be caused by something else. Removing the 'stat is like taking Asprin because you've got a broken leg ! Don't do it, go and get the leg sorted !
David C
RE: Theromastat (verification)
Doug here,
I'm protecting myself from receiving junk mail.
Please click the link below to complete the verification process.
You have to do this only once.
http://www.spamarrest.com/a2?ZGV0AQZmBwcuoKObnJAupzkiqzIlp0OuoKObnJAupwp3ZP5wo20j
Spam Arrest - Take control of your inbox!
http://www.spamarrest.com/affl?124433
You are receiving this message in response to your email to
Doug, a Spam Arrest customer.
Spam Arrest requests that senders verify themselves before
their email is delivered.
When you click the above link, you will be taken to a page
with a graphic on it. Simply read the word in the graphic,
type it into the form, and you're verified.
You have to do this only once per Spam Arrest customer.
Below are the complete headers of the message that this email
was generated in response to.
Received: from adama.asmallorange.com (adama.asmallorange.com [64.22.96.42])
(using TLSv1 with cipher DHE-RSA-AES256-SHA (256/256 bits))
(No client certificate requested)
by mx2.spamarrest.com (Postfix) with ESMTP id 311BEC84E63
for <dougklink>; Tue, 15 Jan 2008 03:32:25 -0800 (PST)
Received: from nobody by adama.asmallorange.com with local (Exim 4.68)
(envelope-from <nobody@adama.asmallorange.com>)
id 1JEk1o-0002QP-Ow
for dougklink; Tue, 15 Jan 2008 06:32:24 -0500
To: dougklink
Subject: [General Amphicar Discussion-t-4614] RE: Theromastat
Date: Tue, 15 Jan 2008 06:32:24 -0500
Reply-To:
MIME-Version: 1.0
Content-Type: text/html
Message-Id: <4614.5350@emailintegration>
References: <4614.5346@emailintegration>
X-Priority: 3
X-Mailer: vBulletin Mail via PHP
X-AntiAbuse: This header was added to track abuse, please include it with any abuse report
X-AntiAbuse: Primary Hostname - adama.asmallorange.com
X-AntiAbuse: Original Domain - spamarrest.com
X-AntiAbuse: Originator/Caller UID/GID - [99 99] / [47 12]
X-AntiAbuse: Sender Address Domain - adama.asmallorange.com
Content-Transfer-Encoding: quoted-printable
Received-SPF: none(amphicar770.com: amphicar770.com does not designate permitted sender hosts)
Webmasters help stop spam and make 50%.
http://www.spamarrest.com/affl?124433/affiliates/index.jsp
