Thermostats
  • Thread starter Thread starter don ross
don ross
My Amphi runs hot ,after installing a Spitfire engine , I have took out the thermostat , and runs alittle cooler,
is this advisable??
don ross
No, it messes up the flow and can cause local overheating. Never run Amphi engine without a thermo. Try and find what is causing the problem. First place to look is blockages in engine or rad. Check hoses. Then look at waterpump and all the other indirect stuff such as ignition timing.
David C
To: DavidC
Sent: Monday, January 14, 2008 9:06 PM
Subject: [General Amphicar Discussion-t-4613] Thermostats
is this advisable??
don ross
Don, do you have the right water pump pulley installed? I'm assuming
you installed a 1500 and they used larger pulleys.
Brad
> is this advisable??
> don ross
> <http://www.amphicar770.com/amphicarforum/sendmessage.php?do=mailmember&u=288>
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.516 / Virus Database: 269.19.2/1223 - Release Date: 1/13/2008 8:23 PM
