I've noticed bubbles forming in the paint near the edges of one of my
Amphicar doors and a close examination has revealed an issue that
I've never seen mentioned in Amphicar discussions. It seems that
although both the inside and outside surfaces of the car were painted
quite well during restoration, not enough care was taken to the lower
edges of the body panels and the doors. Careful examination reveals
that water has been able to work its way between the inner and outer
sheets of the body along these lower edges and caused rust to occur.
It's easy to see how this area gets overlooked since it's often the
area where the paint color ends. When preparing an Amphicar for
paint, every edge where these sheets come together should be
carefully filled and sealed with something to be sure that when the
paint goes on these edges will not be left open to the entry of
moisture. I suppose a good quality seam sealer would do the job but
I've never heard anyone talk about this issue or give recomendations
for what works best here. I would like to hear what you people found
that works best. For you folks currently doing restoratons, I would
carefully check all these areas where sheets comes together, paying
particular attention to areas that get under water when the car is
swimming. Don't forget the areas that are under the aluminum edge
strips too since you can't expect these strips to keep water out and
water that gets behind those strips will have an even tougher time
drying out. How about some tips from you guys with experience
restoring these cars.
