Cameron in UK
We have been working on a car with replacement brake linings and all 8 are the same long length. On a quick test it stopped well and we saw no issues - we thought the need for the short lining on the rear leading shoe was that without it the brakes would lock up in reverse - but thinking now that doesn't make sense as the lining works the same both ways.
So it must be to do with balance and weight transfer under braking. We know that the front axle of a car has much more load under heavy braking and therefore on disk systems the rear disks are smaller to avoid the rear wheels locking up (which would not be good in any car - but particular Amphicar with short wheelbase, high centre of gravity and no ABS) so our thoughts are Amphicar made that lining shorter to reduce that risk. Although Amphicar front brake will always work better as they each have 2 pistons so maybe there was another reason !
Ideas anyone ?
And who is using the same length linings all round ? Any issues ?
Ideas anyone ?
