Thanks...One more thing...
  • Thread starter Thread starter Marty_Peters@gillette.com
Thanks for all the details on keeping our little beauty on the trailer
and doing it right.
One more thing: I need to change the oil. Do you think the drain plug
is straight in from the bilge plug hole?????NOOOOOOOOO, it is rear
about .50 and I can't get at it without damaging the bilge hole
threads. This is driving me nuts because I'm an oil change fanatic.
Any Ideas. I thought about sucking the oil out by using the swimming
pool pump; but I don't think that would be too cool. I need a cool
tool.
Marty Caryl
BUOYANT
64 Turq
If your oil hole is off center odds are that your motor mounts may
need replaced to. One way you can change it is to use a bilge suction
pump it is a device that sucks it up through the dip stick area. I
recieved one courtesy of the Mt Dora swim in (coming up in March make
your plans now) you can get tese through a marine supply center looks
like a bicycle pump hooked to a gas can. I also have seen a version
at pep boys that uses a drill and I think Harbor freight has a
version also.
Doug
