Randall Bograd
My temperature gauge does not work.
Here's what I've tested:
The wiring is correct.
I've just replaced the sending unit.
There is juice to the negative terminal of the gauge and when I ground
the positive, the needle moves to the left.
I've checked continuity to the sending unit and that's okay.
With the car running, I've grounded the wire at the sending unit and
again, the needle moves.
I believe I let it run long enough to heat up (10 minutes), but no
movement.
Any ideas?
Randy
Blue '67
movement.
Any ideas?
Randy
Blue '67
