Tampa Tommy is the star of the ball with a glass slipper
Re: Re: Tampa Tommy is the star of the ball with a glass slipper
<table><div style="font-family:times new roman, new york, times, serif;font-size:14pt"><div style="FONT-SIZE: 14pt; FONT-FAMILY: times new roman, new york, times, serif">Tommy,
<div style="FONT-SIZE: 14pt; FONT-FAMILY: times new roman, new york, times, serif">You can just create a folder in Yahoogroup although space is limited.
<div style="FONT-SIZE: 14pt; FONT-FAMILY: times new roman, new york, times, serif">Alternatively, go to amphicar770.com and upload to the photo gallery.
<div style="FONT-SIZE: 14pt; FONT-FAMILY: times new roman, new york, times, serif">Mike
<div style="PADDING-LEFT: 5px; FONT-SIZE: 12pt; MARGIN: 5px 0px 5px 5px; BORDER-LEFT: #1010ff 2px solid; FONT-FAMILY: times new roman, new york, times, serif">----- Original Message ----
Sent: Wednesday, December 12, 2007 7:47:27 PM
Subject: [amphicar-lovers] Re: Tampa Tommy is the star of the ball with a glass slipper
<div id="ygrp-text">
--- In amphicar-lovers@ yahoogroups. com, David Derer <dmd@...> wrote:
> http://www.theclass icboathouse. com/glassslipper 58.html
Hi guys. I was going to post some pictures. Do I need to create an
album to post them. Can't I just post them in with the text like all
the boat sites? Still learin. Tommy in Tampa
--- In amphicar-lovers@yahoogroups.com, "tommyintpa" <tommyintpa@...>
If you want to, you can grab my quick and dirty Javascript slide show
code to get a quick display show such as at:
<http://www.amphicar.net/aboat2/GrapevineGetaway/index.html>
Not as "modern" as other albums available, but it is easy to customize
and keep the small code scripts (about 20k) in a common directory
pointing each folder of pictures to the common stuff. Basically, if
you are interested, download:
<http://www.amphicar.net/aboat2/slideshw/slideshw.zip>
and unzip it into a directory called "slideshw". Then each time you
have a new set of pictures, you copy the "index.htm" template file
from there into a new folder for those pictures and edit it for the
number of pictures. (there a 2nd redundant copy of index.htm called
index.htmx in the zip file just in case you mess up the template by
accident). Then when you access the edited "index.htm" file from your
picture folder it will access the common code and do all the rest. It
does depend on a consistent structure. Look at the bottom of that
index.htm sample file and you can see how to set it up. .... or ask
me if you get confused. You shouldn't have to change any of the other
files unless you are really ambitious, and if so, as it is all simple
Javascript it is easy to tweak. BTW, it works from a internet
server, or just as well from a local directory or CD. Someday I may
add captions, but haven't desired that yet.
Al Heath
ABOAT*2
