Re: Re: system check
Excellent. Lights actually work!!!
Thanks John.
Randy
On Thu, 07 Nov 2002 20:12:22 -0000 "Cap'n John" <minnow@amphicar.net>
writes:
> --- In amphicar-lovers@y..., rdboggie@j... wrote:
> > I've yet to put the engine in, but the car is wired. I'd like to
> check the integity of the wiring. Is there a way I can safely
> energize the system using my battery charger? Is has a 2 amp and 6
> amp mode.
> > Thanks,
> Randy,
> -Remove all your fuses 1st!!
> -Check to be sure you have power where you expect it to be.
> -Check all your grounds again (did you use star washers *between*
> the
> eyelets and the screws and *not* between the body and the eyelet?
> The
> best connection to the body is through the eyelet to the star washer
> into the threads and NOT the body's painted surface)
> -Apply 12V @ the 6A level @ your battery cables and a good ground.
> -Feel all of your wiring harness for hot spots (indicate possible
> short) especially near connections.
> -Move around the connections looking for sparks or broken wires.
> -Replace your fuses 1 at a time. If they blow, find and fix the
> problem before you put in another.
> -Once again, feel the fuses and then the wiring harness again for
> heat.
> -Now go back and move/shake/pull/push the connections again while
> accessories (lights, signal etc) are on (one at a time) and observe
> intermittent operation.
> -Correct any problems.
> It's not the wire that makes it work, it's the smoke within.
> Don't
> let the smoke out of the wires or it won't work!
> Cap'n
> THE AMPHICAR-LOVERS LIST
> Archives:
> visit:
> at:
> amphicar770@yahoo.com
