Synthetic Brake Fluid?
Tedredamphi
What type and brand of synthetic brake fluid are people using these days? Even more specific - What brand of synthetic brake fluid have people used "for a long time" without any problems?
Ted
I use silicone brake fluid off the shelf at my local NAPA store. I always thought silicone fluid is all the same. I would be interested in knowing if theres another brand thats better. Thanks!
I've switched my cars to NAPA synthetic a couple of years ago and it's been working fine.
Canadian four amphs
This type of fld, will not damage paint as std does, and is a better choice around water, but is much harder to keep from leaking, keep a good lookout for leaks.
This Fld. starts out a purple colour but seems to change after time in the car.I do not know why, anyone out there know?
GORD SOUTER
mschlem Non-synthetic gear lube General Amphicar Discussion 4
S Re Synthetic oil General Amphicar Discussion 5
D Synthetic bikini was it wrong? General Amphicar Discussion 1
