SV: Re: engine and transmision - Clutch Chatter Cause??
Bo Strander
<table bgcolor="white" lang="SV" link="blue" vlink="blue" style="tab-interval:65.2pt">
<div class="Section1">
<p class="MsoNormal"><font size="2" color="navy" face="Arial"><span lang="EN-GB" style="font-size:10.0pt;font-family:Arial;color:navy;mso-ansi-language:EN-GB">Just
a word from an over-sea customer: Worth every cent!!!!!!!<o:p></o:p></span></font>
<p class="MsoNormal"><font size="2" color="navy" face="Arial"><span lang="EN-GB" style="font-size:10.0pt;font-family:Arial;color:navy;mso-ansi-language:EN-GB"><o:p></o:p></span></font>
<p class="MsoAutoSig"><b style="mso-bidi-font-weight:normal"><font size="3" color="navy" face="Arial"><span style="font-size:12.0pt;font-family:Arial;
color:navy;font-weight:bold;mso-bidi-font-weight:normal;mso-no-proof:yes">Med
v?nliga h?lsningar /Best regards<o:p></o:p></span></font>[/b]
color:navy;font-weight:bold;mso-bidi-font-weight:normal;mso-no-proof:yes">Bo
Strander<o:p></o:p></span></font>[/b]
color:navy;font-weight:bold;mso-bidi-font-weight:normal;mso-no-proof:yes">AK
OPTIK AB<o:p></o:p></span></font>[/b]
<p class="MsoNormal"><font size="2" color="navy" face="Arial"><span style="font-size:
10.0pt;font-family:Arial;color:navy"><o:p></o:p></span></font>
<p class="MsoNormal" style="margin-left:65.2pt"><span class="GramE"><font size="2" face="Tahoma"><span style="font-size:10.0pt;font-family:Tahoma">----<span class="SpellE">-Ursprungligt</span> meddelande-----
<span style="font-weight:bold">Fr?n:</span>
amphicar-lovers@yahoogroups.com</span></font></span><font size="2" face="Tahoma"><span style="font-size:10.0pt;font-family:Tahoma">
[mailto:amphicar-lovers@yahoogroups.<span class="GramE">com]</span> <span style="font-weight:bold">F?r </span>John Friese
<span style="font-weight:bold">Skickat:</span> den 18 oktober 2007 09:24
<span style="font-weight:bold">Till:</span>
<span style="font-weight:bold">?mne:</span> [amphicar-lovers] Re: engine
and transmision - Clutch Chatter Cause??</span></font>
<p class="MsoNormal" style="margin-left:65.2pt"><font size="3" face="Times New Roman"><span style="font-size:12.0pt"><o:p></o:p></span></font>
<div style="position:relative" id="ygrp-mlmsg">
<div style="float:left;z-index:1" id="ygrp-msg">
<div id="ygrp-text">
<p style="mso-margin-top-alt:5.0pt;margin-right:0cm;margin-bottom:12.0pt;
12.0pt">
A number of things can cause chatter, disk contamination or uneven
wear, deterioration of the springs in the old style pressure plate, a
loose or misaligned flywheel and a few other things too.
Unfortunatley ther is no way to look at these parts and <span class="GramE">be</span>
sure they
will work smoothly when you put them together. +
Several years ago I had an original clutch that chattered so bad I
thought the tranny gears would break. <span class="GramE">After 2
"professional"
rebuilds, the chatter was just the same. </span>This is one reason that I
designed the high performance clutch system which uses a moderm
diaphram style pressure plate, has a larger surface area and requires
no modification whatsoever to put in your Amphi. Changing out that
old clutch with a modern type is the only way to <span class="GramE">be</span>
sure the thing
<span class="GramE">will</span> be smooth. <span class="GramE">Being sure is a nice
thing because it sure is a pain
to change out a clutch once everything is back together. There are
almost 70 of them in service at this time.
</span>
<span class="GramE">John Friese
--- In </span><span class="MsoHyperlink"><u><font color="blue">amphicar-lovers@<wbr>yahoogroups.<wbr>com</span></span></font>
<font size="3" face="Times New Roman"><span style="font-size:12.0pt;font-family:
"Times New Roman";mso-fareast-font-family:"Times New Roman";mso-ansi-language:
SV;mso-fareast-language:SV;mso-bidi-language:AR-SA">, Ryan Polcin <rpolcin@<span class="GramE">...<wbr>></span> wrote:
> I currently have my engine and tranny out and am about ready to put
it back in the car as well. <span class="GramE">So what does a person need to do
to avoid
the "Clutch Chatter" you speak of. I assume its got to do with
applying the proper torque to the clutch assembly when putting it back
together? </span>Perhaps someone would <span class="GramE">be</span> kind enough
to explain what causes
it and and how to avoid it.
> ----- Original Message ----
> From: John Friese <jfriese@<span class="GramE">...<wbr>></span>
> To: amphicar-lovers@<wbr>yahoogroups.<wbr>com
> Sent: Tuesday, October 16, 2007 12:45<span class="GramE">:35</span> PM
> Subject: [amphicar-lovers] Re: engine and transmision
> Tim,
> The clutch disk alignment tool has EVERYTHING to do with getting the
> engine and tranny together and NOTHING to do with clutch chatter.
> John Friese
> 67 White
> 67 Red
> --- In amphicar-lovers@ yahoogroups. <span class="GramE">com,</span>
"rlgreen_55" <rgreen@> wrote:
> > Using a clutch alignment tool will assure that all is lined up
> > correctly and hopefully eliminate clutch shutter. <span class="GramE">Putting
the engine
> > and tranny together before installing is the way to go.
> > --- In amphicar-lovers@ yahoogroups. com,</span> wick68355@ wrote:
> > > Now that I have my engine out of the Amphicar, I decided to pull
the
> > trans
> > > to rebuild it. My question is, can the engine and trans go back
in as
> > a unit?
> > > <span class="GramE">Tim(</span>lotta work for the winter) Wick
> > > ************ ********* ********* ******** See what's new at
> > http://www.aol. <span class="GramE">com</span>
____________<wbr>_________<wbr>_________<wbr>_________<wbr>_________<wbr>_________<wbr>_
> Boardwalk for $500? <span class="GramE">In 2007? </span>Ha! Play Monopoly
Here and Now (it's
updated for today's economy) at Yahoo! <span class="GramE">Games.
> http://get.</span><span class="MsoHyperlink"><u><font color="blue">games.<wbr>yahoo.<span class="GramE">com/<wbr>proddesc?</span><wbr>gamekey=monopoly<wbr>herenow</span></span></font>
<p class="MsoNormal" style="margin-left:65.2pt"><font size="3" color="white" face="Times New Roman"><span style="font-size:12.0pt;color:white"><a href="http://get.games.yahoo.com/proddesc?gamekey=monopolyherenow"><font color="white"><span style="color:white;text-decoration:none;text-underline:none">
</a>
W engine and transmision General Amphicar Discussion 4
SNOWBIRD Engine surprise General Amphicar Discussion 1
D Engine Draft Tube General Amphicar Discussion 3
Jon March Proper engine break-in General Amphicar Discussion 4
mike_israel 2-ton engine hoist for $143 General Amphicar Discussion 0
Jon March Engine compartment - !@# manual scraping. stripping, degreasing, sanding, priming, painting General Amphicar Discussion 6
P cautionary tale (my engine upgrade experience) General Amphicar Discussion 14
okey0 Engine OUT....how to mount on stand now? General Amphicar Discussion 9
Akamphi Engine oil priming tool General Amphicar Discussion 3
Ken Chambers Entertaining engine rebuild General Amphicar Discussion 0
Akamphi Spit 1500 engine break in. General Amphicar Discussion 1
AHite Possible Engine Conversion General Amphicar Discussion 8
S Pulling an engine General Amphicar Discussion 7
A engine timing and dwell General Amphicar Discussion 3
Midwest Amphicar Engines engines who needs an engine General Amphicar Discussion 4
azpaul50 Engine Cover Luggage rack General Amphicar Discussion 6
Midwest Amphicar Engine cover holes or how I spent today General Amphicar Discussion 1
B Re: Engine cooling fan General Amphicar Discussion 0
B engine cooling fan General Amphicar Discussion 2
amphicarian Engine advice General Amphicar Discussion 19
DavidC Amphicar engine in Alabama General Amphicar Discussion 0
A engine milage and mechnical status General Amphicar Discussion 7
K Engine compartment paint. General Amphicar Discussion 2
C engine rebuild General Amphicar Discussion 1
C Underside hull paint and engine compartment paint General Amphicar Discussion 6
W engine manifold mystery General Amphicar Discussion 7
B SV: SV: Re: Engine cooling / Fan noise General Amphicar Discussion 0
B SV: Re: Engine cooling / Fan noise General Amphicar Discussion 1
D engine personalities General Amphicar Discussion 1
W Engine cooling / Fan noise General Amphicar Discussion 6
B 1147 cc engine advice needed General Amphicar Discussion 2
J Harley engine ---Lake Ozarks next week General Amphicar Discussion 1
B Engine Dies When Hot General Amphicar Discussion 9
S Wankel Engine in an Amphi General Amphicar Discussion 5
S Wankel Engine General Amphicar Discussion 3
S Engine gasket sets General Amphicar Discussion 1
