In a message dated 10/17/02 7:09:33 AM Pacific Daylight Time,
echassignet@rsmas.miami.edu writes:
> Seems common. My front left wheel is also stuck. What is the best way to
> unstuck it? Removing the tire and gently tapping on the steel cover did
> not help. Suggestions appreciated.
> Eric "in Miami"
Hi Eric, Put the tire back on and rock it back and forth it will pop free.
You can't hurt it, the front axle is so light that the tire will just slide.
Crack the bleed valves loose on that wheel. If there is pressure it is a
swelled brake rubber line or bad master cylinder. If not then you are
suffering the mystery syndrome. We will figure it out soon.
Eric when you get rollin' again haul that Amphi up to see us, we have good
lakes up here. Tommy in Tampa
