Stripped Amphicar body weight
Akamphi
Would any of the Amphi guru's out there be able to give me a rough weight front and rear of the Amphi hull? Im going to tow mine out of Alaska this summer and the body is stripped and in fresh paint. it includes doors and hoods. No suspention on it and I plan to bolt the brackets I have mounted to the axle tube flanges directly to the trailer. I'm wanting to get a stable tounge weight for the drive and think the tail will be better forward as it's likely heavyer. I'd like to calculate my tounge weight estimate and where exactly to bolt it down.
bkahler
Craig,
I can't give you any weight info but I do have one concern about bolting it
to the trailer.
From past experience I do know most trailers flex (sometimes a lot depending
on the road condition) so if you're going to bolt the hull to the trailer I
would be very concerned with the hull getting tweeked in transit.
Just something to consider as you're fastening it to the trailer. Possibly
you can do something to minimize the stresses.
Good luck!
Brad
Cap'n John
I've transported many bare hulls and you're better off just strapping it down. Set it on 2x6s across where the oscillating arms enter the hull. Run ratchet straps thru door openings angled back and towards the front to apply fwd and rear ward pull. This will allow flex and prevent any filler from cracking. My best guess is a bare hull weighs about 1000#s and is fairly evenly balanced f2r.
Sent from my BlackBerry
-----Original Message-----
Date: Mon, 1 Feb 2010 20:31:35
To: <rma@amphicar.com>
Subject: RE: [General Amphicar Discussion-t-20678] Stripped Amphicar body
weight
Craig,
to the trailer.
Good luck!
Brad
Akamphi
Thanks to both of you. Love this group! :)
I hadn't considered the flexing issues. It does sit up fairly high on the brackets I made as well so removing them entirely and using a 2 x 6's sounds like a better idea. It's got beautiful fresh Viper paint and the doors are on it so I'll have to figure out something for strapping it down. The Alcan can have some pretty bad frost heaves so I really need to prepare it for a rough trip. I'll go slow for sure but there is always that unexpected pot hole or crater as we call them up here.
I wont be making the trip until May at the earliest...
CapnJohn
If your doors have the seals on the body and on the door installed, be sure they are closed tight and engage the water locks to minimize vibrations. I would suggest removing the doors and pack them seperately in the truck or wrapped and strapped to the floor of the hull for protection to allow you to strap the hull down securely. The time to remove the doors may save you hours of paint repairs later. Place some heavy duty rubber over an old towel over the knife edge along the door opening to protect your straps and finish from abrasion.
Akamphi
But my doors close so well right now..... :( But your right John. I was thinging about that last night and think removing them is the way to go on such a long and rough trip.
Cap'n John
Re: Stripped Amphicarbody weight
An old trick is to drill an 1/8" hole thru each door and thru the hinge plate. Then use the same bit in the hole to realign hinge to the door upon re assembly.
Date: Thu, 4 Feb 2010 02:06:51
Subject: RE: [General Amphicar Discussion-t-20678] Re: Stripped Amphicar
body weight
But my doors close so well right now..... <http://www.amphicar770.com/amphicarforum/images/smilies/frown.gif> But your right John. I was thinging about that last night and think removing them is the way to go on such a long and rough trip.
Quote:
bkahler
Good idea, I'll have to remember it.
Brad
On Wed, Feb 3, 2010 at 9:41 PM, Cap'n John
> re assembly.
> From: Akamphi <>
> To:
> body weight
> http://www.amphicar770.com/amphicarf...ies/frown.gif><http://www.amphicar770.com/amphicarforum/images/smilies/frown.gif%3E>But your right John. I was thinging about that last night and think removing
> Quote:
> from abrasion.
bkahler
Re: Stripped Amphicar body weight
Craig,
I just finished up a move where we moved from Arkansas to Kentucky. 24
moving trips to move cars, tools, equipment, etc.
There is a 10 mile stretch in Arkansas on I-40 that is so rough it
continually loosened and even popped my straps off of my vehicles. Even
taking that stretch at 50 mph (with semi's blowing by me) didn't help a
lot. I had to take extra precautions on strapping just because of this
stretch of road.
I can't even begin to imagine how bad the Alcan highway is going to be for
you. I don't envy you having to make a trip like this with a freshly
painted Amphicar.
Good luck!
Brad
jwillia
Hi Craig
This is Jeff from Alaska and Seattle. We spoke a few times a while back. I shipped my car out of Alaska 3 years ago, because it was much easier to restore here in the States. When I did I put it on a Barge, it cost a little over $1000. It was well worth it as it goes in a Van and is well protected. If you are interested this method. Northland Services in Achorage is the outfit I used. Are you moving out of Alaska ?
Take Care
Jeff Red 62
To: jeffreyd_7@hotmail.com
Subject: RE: [General Amphicar Discussion-t-20678] Re: Stripped Amphicar body weight
Date: Thu, 4 Feb 2010 09:09:23 -0500
Craig,
stretch of road.
painted Amphicar.
Good luck!
Brad
Akamphi
Hi Jeff,
Yea we moved last month. I still have an RV up here and some tools in the garage but have an offer pending on the house so may be moving that to storage soon. I fly back and forth between OR every month now. I'm on teh fence about getting it outside. First off it's a shell in fresh paint with no suspention. Most of the shipping out fits wont touch it without alot of disclamers. I have to drive the RV out anyway and plan to haul some of teh shop tools on a trailer so thats the way I'm leaning. But it is a rough trip and would be pretty slow going. At least teh RV has a rear cam so I can keep a close eye on it.
Hi Craig
Take Care
Jeff Red 62
Akamphi
Thats my biggest concern. Loosening straps. But I do have the option of actually bolting the car to the deck. The suspention is off the car and its sitting on brackets bolted to teh axle tube flanges that bolt to dolly wheels. My thought is to remoce the wheels and bolt it to the deck. But there is the flexing issue to consider. I might build a pallet to bolt it to and strap that down instesd.
Still got 3 or 4 months before teh trip so plenty of time to figure it out.quote=bkahler;41219]Craig,
stretch of road.
painted Amphicar.
Good luck!
Brad
On Tue, Feb 2, 2010 at 4:50 PM, Akamphi <>wrote:[/quote]
bkahler
Craig,
Just a thought. Your idea of a pallet makes a lot of sense. However you
might want to consider when strapping the pallet to the trailer you might
want to find some small used tires and set the pallet on top of the
tires. This would provide you with a "suspension" type ride for the
pallet. If you went this route you could bolt the amphi hull to the pallet
securely which means you wouldn't have to worry about straps ruining your
new paint job. You can use any number of required straps side to side and
front to back to hold the pallet on the trailer. From my my perspective the
biggest issue you're going to face is the roughness of the Alcan highway.
If you can provide a suspension for the pallet to ride on you should be home
free.
Hope this helps!
Brad
> stretch of road.
> painted Amphicar.
> Good luck!
> Brad
[/quote]
Hi Craig,
I rather like that barge idea since a sweet new paint job is sooo fragile. Barring that, I would take whatever time is necessary to bolt the suspension parts back on the cars and strap it down by the wheels. I certainly wouldn't put any straps on the painted surfaces. In my enclosed trailer I have over wheel straps on the front and strap the rear wheels through the wheel slots. Given the roughness of the trip you expect, and assuming you already have the wheels painted or powder coated, I would use over wheel straps on the rear too. This way the suspension takes care of all the bumps and the car should be just fine. An enclosed trailer is nice for long trips since I wouldn't want any kind of cover rubbing on the paint either.
Enjoy,
Akamphi
Right now the only thing left in Alaska is the body. I don't have any tools up here of a place to work on it either or I'd reinstall the suspension. The car is shrink wrapped at the body shop and I was thinking about wrapping that in packing blankets as well. Its an open deck trailer but has provisions for front and side panels that will be higher then the car. I'd tarp over that with a ton of rope to prevent it from catching the wind.
The barge is appealing but I've heard bad things about autos in shipping containers coming loose in a storm and getting tossed around inside.
CapnJohn
Craig,
Bolt the hull to 4x4s that extend 2' beyond the hull width, bolt 2 or 3, 2x6s to the ends and middle of the 4x4s forming a frame then place a tire under ea corner. Use 10,000lb min ratchet straps to secure the wood frame to the deck. She would be suspended by the tires and securly attached to the frame much like a large pallet.
You dont wan't any covers touching the car. The wind flapping the cover will do far more damage to your paint than anything. Shring wrapped is perfect as it will not rub the paint.
Akamphi
Its shrink wrapped now and I plan on wrapping in in packing blankets as well. The trailer also has a front and sides that are higher then the car. I like the tire pallet idea.
chasgould
I would get an old mattress (preferably temperpedic, but any kind
would do), and then lay the shell on that and use ratchet straps to
crank it down tight against the mattress.
> Even
> help a
> stretch of road.
> be for
> painted Amphicar.
> Good luck!
> Brad
[/quote]
Craig:
As you are near Fairbanks, do you barge it down the Yukon or do you have to
get it to maybe Anchorage first?
Last time I shipped anything by barge in Alaska, the barge sank before it
got to the Bering Straits.
El Cajon, CA USA
WB6WSN
1961 Amphicar
1987 MB 420SEL
_____
Sent: Thursday, February 04, 2010 12:33 PM
To: edprice@cox.net
body weight
up here of a place to work on it either or I'd reinstall the suspention. The
containers comming loose in a storm and getting tossed around inside.
Craig in Alaska
2006 Jeep Rubicon, Solar yellow
1966 Amphicar, Now Viper Red
19XX Sexy Red Head, Loaded with every option I ever wanted!
Midwest Amphicar
Get that shrink wrap off as soon as you get back. If that paint is really fresh 30 days or so I would take off now. Wrap it the day you move it. Later Dave
mike_israel 2021 Amphicar Photos Contest General Amphicar Discussion 20
J 1967 Amphicar Tub Toy Restorations in progress 4
mike_israel The only car I consider to be way cooler than the Amphicar General Amphicar Discussion 2
T Parting ways with my 64 Amphicar General Amphicar Discussion 0
AmazingOne Restored 1964 Amphicar for sale General Amphicar Discussion 0
chapron67 Wanted to buy: Nice, useable Amphicar. General Amphicar Discussion 3
mike_israel Annual costs of maintaining an Amphicar (Forum) ... General Amphicar Discussion 10
Jon March lot #012 - The next big Amphicar auction: end of This week! - lot #012 General Amphicar Discussion 4
strandweiss62 RHD Amphicar sold at Mecum General Amphicar Discussion 2
C Amphicar with Buick V6! General Amphicar Discussion 4
DavidC Amphicar club gift. General Amphicar Discussion 3
Andreas Gomoll „The Uganda-Amphicar“ - Brakeparts needed... General Amphicar Discussion 0
Andreas Gomoll ... my Amphicar has some specials.... Restorations in progress 2
B Amphicar Tow Bar General Amphicar Discussion 0
B Celina Amphicar Record General Amphicar Discussion 3
T Amphicar Furniture General Amphicar Discussion 6
mike_israel Amphicar Hawaiian Shirts - Order Deadline Approaching General Amphicar Discussion 0
Jon March the 3 different Amphicar factory driveshafts General Amphicar Discussion 2
sdreich Amphicar Transmissions General Amphicar Discussion 12
L long distance moves for Amphicar General Amphicar Discussion 6
sdreich Amphicar Hubcaps on eBay and More General Amphicar Discussion 4
LSolheim 2018 Clearlake Seaplane - Amphicar: Fly & Swim-in General Amphicar Discussion 0
Jon March Amphicar chase-scenes General Amphicar Discussion 0
Midwest Amphicar Central Florida Amphicar Swim In General Amphicar Discussion 4
Jon March GREAT Amphicar footage from the hot new Northeast "Naples Swim" General Amphicar Discussion 0
scottamphi What Pertronix Fit My Amphicar General Amphicar Discussion 6
mike_israel Merry Christmas & Joy to the Amphicar World General Amphicar Discussion 1
BlueFin Scam Amphicar Ad General Amphicar Discussion 11
mike_israel New Amphicar Children's Book General Amphicar Discussion 4
mike_israel Amphicar on Jay Leno's Garage General Amphicar Discussion 9
B Amphicar Fuses?? General Amphicar Discussion 2
Jon March Sun June 7 - "worlds fair edition" Amphicar?! General Amphicar Discussion 2
mike_israel New Walt Disney World Restaurant Offers Amphicar Rides General Amphicar Discussion 42
mike_israel Do you think this part will fit an Amphicar General Amphicar Discussion 2
dutchamphi Inspector Clouseau-Amphicar episode 1968 General Amphicar Discussion 6
auburnamphi Amphicar Owners In Georgia General Amphicar Discussion 2
C Amphicar article in Maine Magazine General Amphicar Discussion 1
