I visited the Disney Springs Boathouse yesterday. I took these photos of their cars. You can see the mod’s are quite extensive. They run these cars many times per day, so the modified are for reliability, continuous use, and to accommodate passengers safely. There are quite a few differences between individual Amphicars, but here are some common changes.
In the engine compartment:
* New radiator, shroud, and twin electric fans.
* Alternator.
* Larger muffler, with heat insulation.
* Quite a few electrical changes, with new relays.
* An additional bilge pump, with tubing to make pumped water spray up, so it’s visible.
* A fire suppression system.
Body/exterior:
* Doors replaced with fiberglass reproductions, with no door glass.
* Fiberglass hoods.
* Aluminum boat props, instead of our original plastic. There are quite a few weeds in their lake, and they day there were breaking prop blades.
Interior:
* Convertible top removed, to give more rear seat space, and accommodate life jackets.
* Some have added instruments, like voltmeters and cylinder head temp gauges.
* Many have radios removed.
Likely many other changes, too.
They run a nice operation. It's quite popular.
Doug
