Sounds like fuel vaporisation, first check the 5mm thick heat insulating
gaskets are between carb and manifold and fuel pump and block, then insolate
the fuel pipe, could also put a heat shield between manifold and carbs as
fitted to later cars, even try a different type of Gasoline.
To: amphicar groups
Sent: Monday, June 18, 2001 2:19 AM
Subject: [amphicar-lovers] starting problem
can anyone suggest what I can do. The car starts and seems to run fine, but
when it is hot it does not start after being off for a few minutes.
martin@discover-net.net
Yahoo! Groups Sponsor
To: amphicar groups
