G
G_Zink_us@yahoo.com
Hi all,
I need some advise on a "no start" problem. Over the last couple of
months, there have been a handfull of times when I would turn the key
and get a click(not quite a click but don't know how else to
describe) and I would move or tighten the starter cable at the
starter and I'd be off and running. I had no problems Saturday and it
started several times but yesterday I could not get it started. All I
get is that click. Battery is fully charged and I removed and re-
tightened the starter cable. All the solenoid wires appear to be on
and tight. I'm thinking that my blaming a loose connection at the
starter when this happened before may have been incorrect and it
might actually be the solenoid because now, with the key on, I press
the solenoid button, I get no sound at all. This seems odd because I
get the click when I turn the key.
I searched the archives and didn't see anything on the subject so I'm
seeking advice from all of you with more experience.
1) What's your best guess as to the cause- starter, solenoid, loose
connections, ignition switch?
2) On old Fords, I used to jump two wires on the solenoid to bypass
and start the car to prove the starter was o.k. Can anyone tell me
which two to jump on the Amphi?
3) If the solenoid is bad, does anyone have a part number and make
model of vehicle for an interchangeable one I could get at a local
parts store? Will any model solenoid work?
4) Same question for the starter. Anyone have a part number or a
later year make model? I'd order from Gordon's but I'd really like to
get it going in the next few days and with the weight of the thing,
the shipping would probably be more than the cost of starter.
Starterless in Michigan,
Greg Z
67 Amphi, white (MI "IMABOAT")
Greg Z
