Robert Vondracek
The description "Stainless Steel" refers to steel that will stain less.
John Friese was one of the early ones to purchase my "Stainless Steel
Parking Brake Cables". I buy the cables from Hugh, and change the cables to
stainless. I am very proud of my system and duplicate Hugh's assembly
exactly. I was shocked when John called me an showed me that certain things
were backwards. Fortunately, they were easy for him to swap. Now I send them
out with everything the right way.
An engineer friend says that stainless steel typically resists corrosion for
10-20 times longer than conventional steel. I have heard of steel brake
cables failing after 3 years, so that means mine will last a minimum of 30
years. I wonder if Hugh will sell all his steel ones by then?
Robert "Still Alive" Vondracek
</td></tr>
Attachment: (application/ms-tnef) winmail.dat [not stored]
</td></tr>
