The reproduction white trim.
I start with the front, then rear and last the doors.
rough cut to length and add a few inches
taper the starting end to slide better.
Soak the trim in warm soap water then as you start it pour dish soap on the trim
I install a long screw into the end of trim.With 2 people have one clamp on screw with vice grips and other guide trim into channel.
It, will now slide in very easily..When you get to end pull trim ou off channel a bit and pull past end.Push trim in tight with towel to remove strech,leave a overhang on this end too.If you can leave for a day before final trim, cut back the pointy end and fit into cup. leave other end a bit long and do not put alu, ends on till car is 99% done,, to fit alu, ends pull out of track, fit ends then use Johns method for final reasembly/
Gord S/>>>
