Shifter question
warren
Over the past month or so my gear shift lever felt like it was getting
loose. When I tried to put it into third gear the gear shift lever would
travel well into the passengers leg area. I removed the seat and floorboard
and everything is tight and third gear is less than an inch away from first
gear, however I can push the gear shift lever way over to the right when it
is in neutral. When it is pushed over far enough the mounting bracket P/N
11-43-02 hits the hull and deflects it. Could the spring P/N 11-73-38 be
worn out? It feels tight. Is there some other way to limit the travel of
the gear shifter?
-- Warren
'66 White "FLOATS"
L
Larry & Nancy Solheim
If you have the floorboard still out, Warren, check
the set screw that locates the connector hub/ball onto
the shifter rod back at the transmission. There is a
detent in the rod for the set screw point. If that's
loose it could allow excess play. Good luck!
--LarryS
> like it was getting
> the gear shifter?
> -- Warren
> '66 White "FLOATS"
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
S Shifter rod removal? Drill frame boxes? General Amphicar Discussion 8
D land shifter bracket General Amphicar Discussion 1
A Shifter adjustments (one more time)... General Amphicar Discussion 0
T Shifter adjustments General Amphicar Discussion 1
W shifter General Amphicar Discussion 0
T Question on Gas Pedal General Amphicar Discussion 1
A Tool kit question General Amphicar Discussion 9
Jon March Disney cars question - General Amphicar Discussion 0
Jon March radiator cowl question General Amphicar Discussion 0
okey0 Hauling Question General Amphicar Discussion 2
Jon March Axle tube bushings - a followup question... General Amphicar Discussion 0
Jon March Trivia question - General Amphicar Discussion 2
T Stuck valve AND valve cover question?? General Amphicar Discussion 5
Akamphi Neg ground question General Amphicar Discussion 2
A Question on body shop General Amphicar Discussion 0
BuckeyeFloater Quarters Question Restorations in progress 1
laserfixr Question for Gord General Amphicar Discussion 2
M Question on parts General Amphicar Discussion 1
Midwest Amphicar Fiberglass hood and question General Amphicar Discussion 5
T License Plate Lamp Question??? General Amphicar Discussion 6
T Support Rod Question??? General Amphicar Discussion 7
Ed Price Exhaust Question General Amphicar Discussion 10
T Window Fuzzies Installation Question? General Amphicar Discussion 1
B Question for Mike I. General Amphicar Discussion 1
T Door Mounting Question General Amphicar Discussion 1
T Door Seal Question? General Amphicar Discussion 5
Mark Richardson Accelerator cable installation question General Amphicar Discussion 17
T Bilge Blower Question ?? General Amphicar Discussion 2
Ed Price Steering Geometry Question General Amphicar Discussion 0
Ed Price Chassis Dimension Question General Amphicar Discussion 4
J Convertible Top Question General Amphicar Discussion 12
G Convertible Top Question General Amphicar Discussion 1
T Dashboard Switch Question? General Amphicar Discussion 3
S Triva Question- Castle on Horn Button General Amphicar Discussion 5
T Back bumper question for John Friese General Amphicar Discussion 3
B Insurance Question General Amphicar Discussion 6
P Rotisserie Question General Amphicar Discussion 5
T a question about towing my Amphicar General Amphicar Discussion 2
