mabatts@iname.com
I am having a problem with the sheet metal seams forward of the right
rear wheel where the quarter panel meets the hull behind the raised
1/4 lips. The seam has a 1mm gap for about 8 inches that is leaking
water at a good rate under the door.
What is the best way to re-seal the seam? Is epoxy a better solution
than arc welding and if so what type and how to properly fill that
area to seal it?
I have tried silicone with some success, but the seams open up with
the body flexing.
Any help will be appreciated.
Mike Batts
66 Red
Fenton, MI
area to seal it?
the body flexing.
Mike Batts
66 Red
Fenton, MI
