Seattle Show Update
  • Thread starter Thread starter rogtwo@aol.com
rogtwo@aol.com
I was just advised of a possible glitch if you are going to bring your Amphi
to the Seattle show this coming weekend.
If you are coming by land, then everything is OK, and you can just show up
as described in my previous message.
However, if you plan to come by water, you may not get to tie to the dock.
Apparently you need to be registered for the show to tie to the docks at the
Center for Wooden Boats. However, when I took my Amphi there during a show
earlier this month, I tied up to another boat, and no one objected. In fact,
they
seemed to like me there. Anyway, I now plan to come by land and maybe go in
the water later after I check things out at the show.
If you are coming by land, I'll see you there between 9:00 and 10:00 (or
whenever you get there). If you come by land, you do NOT need to be registered.
You should be able to just drive in.
Hope to see you there.
Roger St. John
