seals
  • Thread starter Thread starter Doug Parsons
Doug Parsons
In response to your questions:
1. the best way to check for water leaking in the car is to check
around your ankles and see if your socks are wet.
If you must replace your seals please be kind to them as we do not
want the animal rights people boycotting our web pages and swim ins
and throwing red paint on our amphis.
Doug 8-)
OR you can call Doug Parsons and Roger Sallee and for a beer or two
they will back you car into the lake while you wade/swim out to
inspect. It works great.
--- In amphicar-lovers@egroups.com, "Doug Parsons" <Dougn200@e...>
> Doug 8-)
> Mike is right- I got that same inspection from him while in Celina.
I guess I owe him a beer or two.
Rick
not
ins
> > Doug 8-)
All jokes aside beware of any oil dripping from axle tunnels. Oil there
means water can also enter trans. ( double lip oil seals) Also gear lube
on inside floor means dry trans. Check bolts on differential cover.
Slipping clutch or excessive chatter input shaft seal. There are still
people out there not using Amsoil. Remember order number 508472. Helps
support Amphi net. For those not at Celina, I got to see Gordons new
production marine light lens. These are excellent. If I didn't have a
chrome nude I would get one. Also the new rubber gasket is great also.
For those with 12volt negative ground and no fuel gauge, J.C. Whitney
has kit with float and gauge for 15 bucks. Cool part is float is direct
screw in fit. No drilling! Gauge mounts anywhere you want. And it is
nice to know fuel level. Cruising for hours at night wouldnt of been
enjoyable having to think about fuel. This Lake Geneva gig might just be
a lot of fun. I've been getting some feed back and turn out might be
surprising . The pressure has been building to get Brown Wonder into
some other color. The 66 is nearly ready for its red paint. I keep
finding little spots Iam unhappy with, more primer more blocking, and
more inspections. All of this so someone else can cruise it. Of course
if Brown Wonder became red and fairly smooth it would sell quickly.
Hmmmmm. Later Dave the Wave
