seal puller/prop removal
tommyintpa@aol.com
Hi all, So this is the deal I made the worlds lowest cost seal
remover, take your broom and cut the dome off the top end, drill
about a 1/8 or 3/16 hole about 1/2" from the end you cut, get a big
(about a # 14)FLAT head wood screw 11/2" long screw it in about half
way, you need to leave 3/4 out of the wood. Now give the broom/puller
to Big Raymond and tell him "please pull that out". He can just reach
through the axle housing, hook onto the double lip seal (that I think
was orignal) and pull it out. The first try the screw was too short
so it took two tries. So we went around to the passangers side and he
pulled it out the first try. Hope you can make use of the info.
Tommy in Tampa Red 67-Corky
Lynne White 64-Snappy
How do I remove the props without killing them, in the book I saw
they were using a puller. Must I?
Thanks again, Greasy Boy
