Seal popped out of hub!?
Jon March
No problem with the driver side rear hub: I pumped with grease evenly and till it came out the front side and backside… But the passenger side hub (you may remember this is the same hub that had the key-play back-and-forth) =- On that one, grease insusted on only coming out the front side
-even through the keyway. Trying to get grease to appear out the rear seal as well, I put the key, nut and washer on to try to prevent grease migration out of the front, to encourage it to come out the backside like the previous hub… But when I did, grease still refused to come out the back side, and instead blew out the seal on the hub side!#@
Grease SHOULD be traveling easily enough in the hub interior to come out the rear seal and not force out the frontside seal - Why would this be ?!
Jon, Turn your seals around. Spring side facing out.
yes !
I've been learning with this topic that "springs outward" on both sides of the rear hubs is the new preferred way – – with the goal being most important to keep water out and manageable to control and keep grease from contaminating the brakes when amy comes out.
The original engineering diagram in the maintenance manual shows the outer seal with the spring facing toward the inside of the hub . With the goal being to prevent grease from contaminating the rear brakes – – but apparently it has been learned that water suck is a bigger problem with seals in that position.
Meantime I pressed out the stub axle to see if the bearing was a shielded type with a dust cover that might have prevented grease from squeezing out the back, or if the rear seal had a dust lip ...and indeed it does have a dust lip but then again so did the Other hub whose seal allowed grease to come through when full. And no, the rear bearing in the problem hub has a traditional metal cage on the balls- no seal that would have further impeded grease travel .
So I remain stymied -my only remaining guess, and I'm not willing to take apart the other hub to look at it., is that although both of the inboard seals on these hubs have an embossing pattern used by Harwal, one is a different pattern versus the other- possibly indicating an older batch with the stiffer springs or rubber , or sourced to OEM vendors to Harwal
Bottom line if grease doesn't come out the rear and you're getting a whole ton of it squeezing out the other end you know you're building up pressure inside that that is more than you want to run with- first sign of being full-stop and be happy (even tho that shit shoulda come out both seals like the other hub#%)
And a tip yesterday on this from Gerry Obara in Mass:
carefully put a toothpick or other pointy-thing to carefully lift the lip of the inside seal to help let grease come thru.
So im getting different opinions. My springs are indeed facing out on the inside hubs. But i was told that many people insist the outer seals have the springs facing in: to prevent grease from coming into the brake shoe area when the hubs are re-greased. Made sense from a contamination/safety angle - thoughts?
