Jon March
1) There is an up & down, sharply angled 3/4" tube on the manifold side of the block on these cars - with an open directed to the bilge on earlier cars, and pinched off on later ones
a) wtf is it?
b) can it please be cut back and capped?! (at least on later ones where its pinched? ....or is it some sort of emergency overflow that somehow re-opens the end-crimp back up in a some sort of over-pressure event?
I would like to cut it back and cap it off neatly of its not used - its original...but its unsightly in my view, and in addition i dont want a messy bilge any more than i need to have if its really not necessary
2) re: the S-shaped, carb-boilover evap-tube on the manifold (fed by a pinhole in the manifold below the carb that needs to be kept open)
I agree with Gord that its stupid to design fuel to dump into the bilge - even if 99% of the time it never does,, and just evaporates off by boiling in that tube. Just scary in a closed bilge. Gord mentions routing those tube-fumes to the air intake -Im imagining one would need a fitting of some kind to attach the hose he recommens to the air cleaner intake hose...ideally, with an L or J shaped elbow inside the air intake, with the opening toward the carb, to help "draw" the vapors or fuel in) - Gord, can you comment or post a detail-pic of it?
(OR - for those with later cars that have the 3/8" oil-vapor/"PCV" intake tube at the bottom of the aircleaner mount, could this fuel-boilover-return be Y'd into it?? - or is it a bad idea to introduce a way for fuel vapor to get into the valve area?
3) I think i recall seeing people delete the clunky square flame arrestor -
a) is it ok to do? (i know its solely the owners final decision whether to do this)
b) if deleted - how do you attach the air cleaner base to the top of the carb - the air cleaner opening is a little larger, eliminating any slide-on fit (nor setscrew) to affix it
how to do??
a) wtf is it?
how to do??
