tommyintpa@aol.com
Hi all, There may be rooms at the Inn on the green, but even if there are not
you should come anyway. There are rooms for sure but you may need to drive 20
minutes to the show. This is very near Disney so there are thousands of rooms
in the area. COME TO FLORIDA it is going to be about 75 degrees here and it
is probably cold where you are. Haven't you had enough? Take a couple of days
for yourself and come to this Amphi event. The work (or whatever) will be there
when you get back. If you need to you can leave your Amphi at the Inn and
drive your car to your hotel, there is room for your car. COME TO FLORIDA you
need a break from that bilgen cold weather. This is good Amphi fun and this year
the boat show has moved us off the point. They put us at the top of the ramp,
in the center of the show so we can swim as much as we care too. COME TO
FLORIDA you will be glad you did. Be at the Inn on the Green at 10AM on Friday
then
we will swim in the beautiful Dora Canal to see the wooden boat parade up
close. They are so nice and so happy to see us. It is great fun. See you there.
COME TO FLORIDA 75 to 80 degrees
Tommy in Tampa FL
then
Tommy in Tampa FL
