Rock River
  • Thread starter dougparsons@ameritech.net
  • Start date
What a great weekend
First a little back ground:
Starting last Sat getting ready
1. Amphi fries marine light wires
2. Starter locks up and takes out rear universal joint
we leave on Wed
3.Yukon Differential locked up had to ge tdave to pick us up it will
be 10days at the dealership to ge it fixed over 2000.00 repair
4. Amphi fries marine light again
5. unfortunate accident on the water with poor chuck
6. Decide to drive amphi home to Dayton
7. have a flat tire
8. fix tire
9. get to indianapolis and stop for gas
10 Accelarator cable breaks
11. Jury rig it and get home by 2 in the morning
Swimming with dave and freinds..... Worth every moment
Doug
Drove
Doug,
There are two strange electrical connections that I've found on
Amphicars that cause the blowing of fuses. Once in particular is in
the wiring inside the flag pole. If you have taken the pole apart and
then reconnected the wires to the lamp base, you'll have two wires and
two terminals on the lamp socket for them to go on. The trouble is
the wires can be connected to either terminal but only one way is
correct. If you connect them the other way it will directly short the
lamp circuit and blow a fuse. Even though the two contacts on the
lamp socket appear the same, one is connected to the outside metal and
the other isn't. Be sure that the wire coming from the center pin on
the post connector is connected to the terminal that does NOT connect
to the outside metal. In normal cars, there would only be one wire
coming from that lower connector and one terminal on the lamp, with
the electrical return path going through the lamp post housing. I
have no idea why Amphicars have such a weird wiring system that can be
so easily mis-wired and cause such a problem.
Another problem area that can blow a different fuse but for the same
reason is at the two back up lamp assembles. Same thing, two wires
and two terminals only one terminal is connected to the outside of the
lamp base and will blow a fuse if those two wires aren't connected to
the correct terminals. This one can be even more annoying though
since the lamp base often makes a rather poor contact with the body of
the car and when the wires are connected backwards it will only
SOMETIMES blow a fuse in the car. Be sure that the wire that measures
zero (or very low) resistance to the body is connected to the back up
lamp terminal that measures zero resistance to it's outside metal
part. Check this at both back up lamp assemblies because a reversed
wire on either side will cause the same fuse to blow.
> we leave on Wed
> 7. have a flat tire
> 8. fix tire
> Doug
> Drove
Gr8cobbler Swimming the Rock River with a Grumman Widgeon Flyover General Amphicar Discussion 2
A Rock River Event General Amphicar Discussion 1
M Rock River in Newville General Amphicar Discussion 1
M Sunday Swim on the Rock River General Amphicar Discussion 1
D Where is Rock the Rock with The Wave? General Amphicar Discussion 0
D Rock the Rock with The Wave General Amphicar Discussion 0
D Lake Geneva Sept 25th Oregon Illinois oct 2nd Rockin the Rock May 2005 General Amphicar Discussion 1
D stretch - Gibson page - trip around World - Starved Rock this Saturday General Amphicar Discussion 0
K Rockin the Rock. General Amphicar Discussion 0
W Rockin the Rock General Amphicar Discussion 1
M Rockin on the Rock General Amphicar Discussion 0
M Wet feet on the Rock General Amphicar Discussion 0
A 1967 Yukon River Flotilla with four Amphicars General Amphicar Discussion 0
Craig Parada Sacramento River Swim-in General Amphicar Discussion 2
Akamphi 1966 Fairbanks News Miner Article About the Yukon River Trip General Amphicar Discussion 7
DavidC Reverse river wave - not for Amphicar General Amphicar Discussion 1
Midwest Amphicar Illinois River really sucks in Peoria General Amphicar Discussion 2
Midwest Amphicar Chicago river run 2009-POSTPONED - General Amphicar Discussion 1
Ed Howard Amphicar on the Seine River General Amphicar Discussion 7
Midwest Amphicar Real tired of cold River dance this Thursday! General Amphicar Discussion 1
LSolheim Bilgy: Potomac River Bound? General Amphicar Discussion 1
Midwest Amphicar Chicago river run 2009 General Amphicar Discussion 9
D Daves River Building Again General Amphicar Discussion 0
D UK Amphicar number 2 is about to reach the end of the road /river General Amphicar Discussion 1
W Amphicar in MIlwaukee River General Amphicar Discussion 0
D River Test General Amphicar Discussion 0
A Big River Magazine (part 2) General Amphicar Discussion 0
A 5 days on the Colorado River General Amphicar Discussion 0
R Driving the Potomac River General Amphicar Discussion 0
D river General Amphicar Discussion 0
M Chicago River General Amphicar Discussion 2
D axle- river General Amphicar Discussion 0
L Colorado River Swim General Amphicar Discussion 0
D nav light river cruise fifth swim General Amphicar Discussion 1
S Moon River General Amphicar Discussion 1
K River Run General Amphicar Discussion 0
T ROCKIN RIVER!! General Amphicar Discussion 0
C Off topic... Ora Stewart Yukon river Amphi owner General Amphicar Discussion 0
C Ora Stewart the Yukon river swim General Amphicar Discussion 4
D River Flooding General Amphicar Discussion 0
