Replacement sun visors
tommyintpa@aol.com
<font style="BACKGROUND-COLOR: transparent" face="Arial" color="#000000" size="2"><font face="Arial" size="2">For $53 delivered, they're a bargain and they look great too. Part number 211 898 551bwh.</font></font>
<font style="BACKGROUND-COLOR: transparent" face="Arial" color="#000000" size="2"><font face="Arial" size="2">Scott Moses..</font></font>
Hi Scott, when your visors are open against the side doorwindows do your visors go straight out? I mean do they run parallel with the edge of the top or do they run down at an angle across the window? Tommy in Tampa</font>
S
Scott
<table bgColor="#ffffff">
<font face="Arial" size="2">I bought and installed a set of the VW bus sunvisors.</font>
<font face="Arial" size="2">I used one original screw hole and drilled two small sheet metal screw holes. The mount covers the original holes so no one's going to ask you what's missing.</font>
<font face="Arial" size="2">For $53 deilvered, they're a bargin and they look great too. Part number 211 898 551bwh.</font>
Daniel & Kathy Gibson
And, if you still have the original plastic mounts, but rotted visors
(like I did), you can get a pair of the bus sunvisors for about $20 or
so, and they fit on the original metal rods just fine.
Dan
> you what's missing.
> Scott Moses..
> THE AMPHICAR-LOVERS LIST
> Archives:
> visit:
> amphicar770@yahoo.com
> This list is provided as a free service. Please support our sponsors
> at:
> When insuring your Amphicar do not settle for anything less than the
> very best coverage available. Visit Hagerty Collector Car Insurance
> today at
> http://www.hagerty.com
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> [click here]
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Daniel and Kathy Gibson
AND...
http://drnooseandjambone.com
S
Scott
<font face="Arial" size="2">I seethat after some ware the visor would want to swing away from the windshield. The problem is, the mount point on the windshield is slanted inward. That means the visor shaft is pointing uphill. </font>
<font face="Arial" size="2">I think I'll just make a plexiglass wedge to raise the lower mounting edge and level the visor. That would also level the visor across the side window.</font>
<font face="Arial" size="2">Scott..</font>
A less expensive replacement for axel slip joint General Amphicar Discussion 2
LSolheim Replacement Coil? General Amphicar Discussion 26
S Replacement License Plate Bulb General Amphicar Discussion 1
S Speedometer Cable Replacement General Amphicar Discussion 4
D Vent Glass Replacement General Amphicar Discussion 1
A NEW REPLACEMENT GLOVE BOXES ARE NOW ON EBAY General Amphicar Discussion 1
W seal replacement General Amphicar Discussion 1
G U Joint Replacement General Amphicar Discussion 4
S Replacement Parts General Amphicar Discussion 0
L fuel pump replacement General Amphicar Discussion 2
T fule pump replacement number General Amphicar Discussion 2
A Replacement Sun Visor General Amphicar Discussion 0
E Replacement Front Shock Source General Amphicar Discussion 0
B Amphicar Universal/Replacement Parts Tips General Amphicar Discussion 0
S Questions about oil change and replacement upholstry... General Amphicar Discussion 2
B Interior Mirror Replacement Recommendation General Amphicar Discussion 1
S Starter Replacement General Amphicar Discussion 0
B rear axel seal replacement General Amphicar Discussion 0
B transmission axel seal replacement General Amphicar Discussion 1
B U-joint replacement General Amphicar Discussion 0
A replacement horn General Amphicar Discussion 3
T VISORS General Amphicar Discussion 0
A Pulleys, Visors ETC General Amphicar Discussion 0
A New Aluminum Visor Brackets with Visors General Amphicar Discussion 2
S Sun Visors General Amphicar Discussion 4
