Replacement Front Shock Source
Perhaps something has gone astray at the Surplus Center web site. The
replacement part for the old-style (an eyelet fitting at both ends, so the Amphi
upper fastener is an upside down U-bracket, not a through-the-hull hole) Amphi
front shock is the Maeco PK22K1, shown at:
<a href="http://www.surpluscenter.com/item.asp?UID=2004012418080856&item=28-1343&catname=engines">http://www.surpluscenter.com/item.asp?UID=2004012418080856&item=28-1343&catname=\
engines</a>
But wait, the picture shows a shock only, without the coil spring and the
rod-end coil spring mounting "dome". This is not the picture they had a couple
of months ago. And the price is $8.99 and there are only 2 left in stock!!!
OTOH, the text description clearly describes a spring associated with this part
(and I paid about $20 each for them a few months ago). And there was a few
hundred in stock then.
Hmm, has somebody bought out ALL of those Amphi-interchangeable shocks? If so, I
wonder WHO? Now who do we know that might want a few hundred Amphi front shocks?
If what's left is just 2 shocks, and they don't even have the springs or
mounting hardware to even accept springs, then we have just seen a big source of
parts evaporate into thin air. And that's the exact reason that I want to cross
any Amphi part to a common commercial part, like a Monroe or a Koni or a
Gabriel. They are big enough makers that, once you find a part, it will be
around in the distribution channels for many years.
Meanwhile, if this isn't just a mix-up at Surplus Center's web catalog site,
then be careful about what you order now. OTOH, at $9 each, and only two left,
maybe it's not important any more.
A less expensive replacement for axel slip joint General Amphicar Discussion 2
LSolheim Replacement Coil? General Amphicar Discussion 26
S Replacement License Plate Bulb General Amphicar Discussion 1
S Speedometer Cable Replacement General Amphicar Discussion 4
D Vent Glass Replacement General Amphicar Discussion 1
A NEW REPLACEMENT GLOVE BOXES ARE NOW ON EBAY General Amphicar Discussion 1
W seal replacement General Amphicar Discussion 1
G U Joint Replacement General Amphicar Discussion 4
S Replacement Parts General Amphicar Discussion 0
L fuel pump replacement General Amphicar Discussion 2
T fule pump replacement number General Amphicar Discussion 2
A Replacement Sun Visor General Amphicar Discussion 0
T Replacement sun visors General Amphicar Discussion 3
B Amphicar Universal/Replacement Parts Tips General Amphicar Discussion 0
S Questions about oil change and replacement upholstry... General Amphicar Discussion 2
B Interior Mirror Replacement Recommendation General Amphicar Discussion 1
S Starter Replacement General Amphicar Discussion 0
B rear axel seal replacement General Amphicar Discussion 0
B transmission axel seal replacement General Amphicar Discussion 1
B U-joint replacement General Amphicar Discussion 0
A replacement horn General Amphicar Discussion 3
F Front bumper General Amphicar Discussion 2
