Removing the engine, were do you split from transmission
topless51ford
Just started working on my Fathers Boat. I want to take out only the engine. Were should I split it from the transmission. At the 20 or so bolts that are before the bell housing from the engine side? or the 4 larger bolts after the bell housing? It looks like they both might work ? Thanks Jerry
topless51ford
Thanks 4 it will be.
