Marty & Caryl
After many conversations with a few intelligent individuals we all
know and respect on the correct positioning of the radial oil seals
in reconditioned oscillating arm or rear wheel assembly, which is
found in the Amphicar Maintenance Manual chapter 4, I have seen the
logic of placing the inside seal, closest to the car with lip out and
the outboard seal with flat side out.
The logic here is that (and I'm using someone else's words that I
have learned) when you grease the assembly the grease goes through
the hub to lubricate the bearings and comes out where the axle goes
in and can be wiped away, it's important that this seal is kept wet
so that's why the seal is backwards. The other seal going with lip
in and flat side out will stop grease from filling your brakes, which
would impede stopping as well as gumming up the works and making a
real mess of things.
Thanks to all that helped us on this task.
We will see you in Celina,
Marty in WI
Marty in WI
