<table>
Dave,
I'm glad you brought the washer thing up. I'm pretty sure I replaced these bearings last year when I replaced a worn drive shaft. I'm usually very careful to watch the sequence of items when I do the removal and then, just to make sure, I compare what I have to the exploded view in the parts catalog, which, unfortunately, doesn't always match up. And I'll never know if some previous mechanic messed up the order.
Should I trust exactly what I see on plate 20 of the spare parts book?
What you call 'spring washers' I believed are labeled item 7 (disc washers).
Should they be oriented this way: ( ) or this way: )(
There is also an unidentified item between the spring washers and the swing axle.
Same is true for outside bearing, between items 3 and 9.
Any help is appreciated. I'd hate to end up with the same problem when all is done.
As always, ever grateful to a great group.
Randy
Blue '67
Gaithersburg, MD
> > whole rear wheel assembly had about 1/4 inch play;
> > not rotational play, but play when I pushed/pulled
> > on the front
> Another problem I encounter more often than not, is the way the spring washers,
> spacer, and bearings are put together. What happens is washers are put in wrong
> and spacing is incorrect. Then hub is smushed on real tight. So taper is jammed
> up the little hubs behind. Makes it about impossible to get hub back off but
> also alllows back and forth movement. **** A sand flea as President, only in
> America!! Poda Poda!!! I still have My bottle of Celina tookillya- Maybe the
> Prez will come out in May. Later Dave the Wave
> ------------------------ Yahoo! Groups Sponsor --------------------~-->
> Give the gift of life to a sick child.
> Support St. Jude Children's Research Hospital's 'Thanks & Giving.'
http://us.click.yahoo.com/5iY7fA/6WnJAA/Y3ZIAA/xiTolB/TM
> THE AMPHICAR-LOVERS LIST
> Archives:
> visit:
> When insuring your Amphicar do not settle for anything less than the very best
> coverage available. Visit Hagerty Collector Car Insurance today at
http://www.hagerty.com
> Yahoo! Groups Links
> <*> To visit your group on the web, go to:
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
> </blockquote>
