Rear axles
markamsdill
Hello All, With the trans out of the car , I want to install the rear axles to be able to move the car around. Whats the easiest way to get the axle back thru the bearings. I was thinking putting them in the freezer and warming the bearings with a torch. I dont have a puller which is probably the correct way to do it.Any ideas would be appreciated. Thank you and have a good day. Mark Amsdill
G rear axles General Amphicar Discussion 1
