I bought a set of Gordons plug and play rear shocks only to learn that they do not fit with my Cooker Radials. I would shim the tire and rim out but the previous owner did not account for this when they mounted the replacement quarter panel so the only two options I have left are switch back to the skinny bias ply tires or find a small diameter spring shock that will work. I prefer option 2.
I have spent a fair amount of time looking thru old posts and did not find the details around the rear shocks and am hoping someone knows the following information. I found a few related posts but they did not have all the information needed on the rear shocks.
Mounted Length
Extended Length
Compressed Length
Stroke Length
Spring Rate
I found these and other that having too much travel they look like they are a darn close fit. If I read this correctly it appears the spring is 2 5/8" diameter which is close to the original. I am not a fan of the chrome but at this point I can live with it.
www.speedwaymotors.com
Aluminum Small Body Coilover Shock, 4 Inch, 325 lb. Spring Rate
Universal Fit, 325 lbs. Spring Rate, 12.00" Mounted Length, Aluminum Shock Body Material 2 5/8" Spring Diameter
https://www.speedwaymotors.com/Alum...-Shocks-5-Inch-300-lbs-Spring-Rate,46605.html
Aluminum Small Body Coilover Shocks, 5 Inch, 300 lbs Spring Rate
Universal Fit, 300 lbs. Spring Rate, 13.10" Mounted Length, Aluminum Shock Body Material
Any insight or comments good or bad is appreciated.
Mounted Length
Extended Length
Compressed Length
Stroke Length
Spring Rate
Pro shocks new aluminum small body coil over shocks are 3 way adjustable. They are fitted with 2-5/8" chrome spring and aluminum coilover kit and make one of the cleanest coil overs on the market for your street rod. Each shock features urethane mounting bushings with both 1/2" and 5/8" mounting...
Loading Products... | Speedway Motors, The Racing and Rodding Specialists
