RAKE CYLINDER SUBSTITUTE
cruiserdog44
Hey Guys,
Thanks for all the help on my rebuild.
Now has anyone used a modern replacement other than the VW Bus
Master?
Please provide details as to which one, make, model, and any retro
fitting needed.
Cruiserdog
Akamphi Wheel cylinder bleed screw General Amphicar Discussion 3
A Amphicar master cylinder conversion to dual master cylinder General Amphicar Discussion 1
S Master Cylinder Seals General Amphicar Discussion 3
D Another red Amphicar for sale JC Whitney master cylinder General Amphicar Discussion 1
J Wheel Cylinder Rebuild Kits General Amphicar Discussion 6
B Fwd: Break Master Cylinder General Amphicar Discussion 2
B Break Master Cylinder General Amphicar Discussion 0
M Wheel Cylinder Rebuilding General Amphicar Discussion 2
M Brake / Wheel Cylinder Bleeder General Amphicar Discussion 0
C Master Brake Cylinder General Amphicar Discussion 0
B Transporter master cylinder? General Amphicar Discussion 4
C Door lock cylinder... General Amphicar Discussion 6
W wheel cylinder pistons General Amphicar Discussion 0
S Ebay- rear brake cylinder problem General Amphicar Discussion 0
A Front Wheel Cylinder General Amphicar Discussion 4
C Master Cylinder Failure General Amphicar Discussion 0
M Dual Circuit Master Cylinder? General Amphicar Discussion 1
A Brake Hose and Cylinder Kits General Amphicar Discussion 1
P Expert Article on Triumph (Amphicar) 4 cylinder engines General Amphicar Discussion 0
R Substitute for Radiator Mount General Amphicar Discussion 4
A Substitute mail carriers ARGHH!!! General Amphicar Discussion 0
E Triumph Engine Substitute General Amphicar Discussion 1
T radiator rubber (buffer) mount substitute 9-30-38 General Amphicar Discussion 1
