Question for Gord
laserfixr
Gord,
As you might remember a heavy set lady stepped on my rear seat and cracked the fiberglas pan under the rear seat pad at Mt. Dora last month. I went to my fiberglas place last week and asked for materials to repair the crack. The counter guy asked me if it is a polyester resin or epoxy. Can you tell me what the type of resin you used to make the pan so I get the proper kind of resin? Thanks
You can use a over the counter Poly resin and cloth screen or fibre mat, Sand the surface with very coarse paper and clean off all grease. You can build up with as many layers as you want for extra stength, but I like it thin to flex when I install it,. I now add siver paper to the bottom to refelect the heat, Also I drill 2 holes in the low spots so water(from your big slashin) will drain off. You let people sit on your Conv. top area when giving rides, I would not do that for many reasons but, If you do you should make up a plywood base across seat area for feet.One fellow made up a snap in plywood seat, padded that sits atop the conv. area.
Many cars have the metal U bar that hold the backrest, in the pic below that have been damaged, I now Stock these.
John Howland Valve cover question General Amphicar Discussion 0
millertyme Restoration question, best rotisserie, and where to mount. General Amphicar Discussion 5
T Question on Gas Pedal General Amphicar Discussion 1
A Tool kit question General Amphicar Discussion 9
Jon March Disney cars question - General Amphicar Discussion 0
Jon March radiator cowl question General Amphicar Discussion 0
okey0 Hauling Question General Amphicar Discussion 2
Jon March Axle tube bushings - a followup question... General Amphicar Discussion 0
Jon March Trivia question - General Amphicar Discussion 2
T Stuck valve AND valve cover question?? General Amphicar Discussion 5
Akamphi Neg ground question General Amphicar Discussion 2
A Question on body shop General Amphicar Discussion 0
BuckeyeFloater Quarters Question Restorations in progress 1
M Question on parts General Amphicar Discussion 1
Midwest Amphicar Fiberglass hood and question General Amphicar Discussion 5
T License Plate Lamp Question??? General Amphicar Discussion 6
T Support Rod Question??? General Amphicar Discussion 7
Ed Price Exhaust Question General Amphicar Discussion 10
T Window Fuzzies Installation Question? General Amphicar Discussion 1
B Question for Mike I. General Amphicar Discussion 1
T Door Mounting Question General Amphicar Discussion 1
T Door Seal Question? General Amphicar Discussion 5
Mark Richardson Accelerator cable installation question General Amphicar Discussion 17
T Bilge Blower Question ?? General Amphicar Discussion 2
Ed Price Steering Geometry Question General Amphicar Discussion 0
Ed Price Chassis Dimension Question General Amphicar Discussion 4
J Convertible Top Question General Amphicar Discussion 12
G Convertible Top Question General Amphicar Discussion 1
T Dashboard Switch Question? General Amphicar Discussion 3
S Triva Question- Castle on Horn Button General Amphicar Discussion 5
T Back bumper question for John Friese General Amphicar Discussion 3
B Insurance Question General Amphicar Discussion 6
P Rotisserie Question General Amphicar Discussion 5
T a question about towing my Amphicar General Amphicar Discussion 2
C 1500 conversion question General Amphicar Discussion 11
D Blaupunkt radio question General Amphicar Discussion 3
D one step away. bilge hose question Plasma/led screen question General Amphicar Discussion 1
