It's more hassle and weight and bulk to pull the engine and trans as a unit,
but it's also safer. If you are good, really know what you're doing, you can
pull the engine without the trans, but the danger of damaging the trans
input shaft and bearings is greater.
Assuming that you are using a hydraulic crane to pull the engine, it helps
to remove the engine cover. What really helps is to raise the front of the
Amphi to give the engine a better angle of withdrawal. Use a hydraulic floor
jack with some 4x4's to block the front as high as you can; then you don't
have to point the timing chain end of the engine as high in the air to clear
the bodywork. One of those adjustable center lift screws can help you tilt
the angle of the engine as the crane picks it out.
Obviously, you have to drop the rear axles to free the transmission. Not so
obviously, don't forget to disconnect the clutch cable bracket from the
transmission case.
Membership Chairman
International Amphicar Owners Club
El Cajon, CA USA
WB6WSN
1961 Amphicar 770
1987 MB 420SEL
_____
Sent: Tuesday, November 02, 2010 6:07 PM
To:
edprice@cox.net
Subject: [General Amphicar Discussion-t-20924] Pulling an engine
Good evening group.
I'm considering pulling the engine out of my car. Is it easier to take both
engine and trans together or separate them while still in the car? Also, any
other short cuts, ins and outs, problems I should be aware of?
Thanks much.
Mike Clark
Stockbridge, Georgia
