Prop U Joints on EBay
C Prop driveshaft u-joints sloppy? General Amphicar Discussion 6
E Inspecting Prop Shaft U-joints General Amphicar Discussion 0
A prop shaft u-joints General Amphicar Discussion 0
SNOWBIRD Prop housing units General Amphicar Discussion 6
Jon March im=a looking for a spare prop General Amphicar Discussion 1
D Prop rpm General Amphicar Discussion 0
scottamphi Prop Key Size General Amphicar Discussion 3
S Re hood and prop rod General Amphicar Discussion 0
amphigill prop rpm General Amphicar Discussion 2
CapnJohn Catastrophic prop failure (new props) General Amphicar Discussion 14
Midwest Amphicar prop shield newly made and installed General Amphicar Discussion 7
T Prop shaft questions please General Amphicar Discussion 11
L Decals (was Re: Noisy Prop Shaft Tubes) General Amphicar Discussion 2
L Noisy Prop Shaft Tubes General Amphicar Discussion 1
T Prop speed General Amphicar Discussion 1
T Prop Cleaning General Amphicar Discussion 6
A Prop Shaft Bearing 3-19-2 Grease General Amphicar Discussion 1
A Space between prop and hull General Amphicar Discussion 2
C Prop shaft torx bolts... General Amphicar Discussion 4
G prop shafts General Amphicar Discussion 4
E Directional Stability, was Looking for used prop General Amphicar Discussion 1
S Looking for used prop General Amphicar Discussion 6
D One prop General Amphicar Discussion 0
M prop. General Amphicar Discussion 1
B independent prop drives General Amphicar Discussion 0
M Tool needed @ Celina for prop shaft assembly General Amphicar Discussion 0
M Prop shaft removal clarification needed General Amphicar Discussion 2
G broken prop General Amphicar Discussion 2
A Prop shaft tool General Amphicar Discussion 4
T seal puller/prop removal General Amphicar Discussion 0
SNOWBIRD 24mm u joints General Amphicar Discussion 3
F U Joints General Amphicar Discussion 0
Canadian four amphs U Joints General Amphicar Discussion 0
W Drive Shaft U joints General Amphicar Discussion 2
T Axle u-joints General Amphicar Discussion 3
G U Joints! General Amphicar Discussion 3
G U Joints. General Amphicar Discussion 0
D 30mm x 81.8 u-joints General Amphicar Discussion 0
B Oil Change Joints General Amphicar Discussion 0
B SV: SV: SV: Propeller Shaft U-Joints General Amphicar Discussion 0
B SV: SV: Propeller Shaft U-Joints General Amphicar Discussion 1
B SV: Propeller Shaft U-Joints General Amphicar Discussion 3
A Propeller Shaft U Joints General Amphicar Discussion 1
