prop shafts
G
Gord Souter
CHUCK>>
Its much easier to put in another prop shaft than change the joints and if
you go to my parts list
#3-19-01 you will; see that I have them for $100.00
If anyone wants my list email me at (info@houseboatvacations.ca)
Also if you are very careful Muratic Acid. As one fellow said (available at
hardware stores ) will clean gas tanks in a few days of rotating to a like
new condition.
I use this stuff all the time in restoration of amphicars, nuts bolts and
small parts.etc.
GORD SOUTER
four amphis
[This E-mail scanned for viruses by Orillia ProNet with Declude AntiVirus]
watercar64
I got the bolts out O.K. and put in mectric bolts
in place of the original , will there be a problem with this;?
olso I have been trying to get in the members area
with celina & elizabeth and it wont let me in ,did they
change the code , I got in before with no problem
WB6WSN
Sent: Monday, January 12, 2004 7:25 PM
Subject: [amphicar-lovers] prop shafts
My bolts there were all severely rusted and/or corroded. Most of the bolt-heads
couldn't be gripped with a socket, box or open-end wrench. Had to crack rust
from hex faces of bolt heads.
Hope you remembered to replace the seals at the hull penetrations. BTW, I notice
that a lot of the original Amphi split-ring lockwashers are bad. A surprising
number will crack and fall off the bolt when you are removing the bolt. I
decided to not re-use any old lockwashers, no matter how good they look.
David Derer
Larry perhaps You need to sit on it and rotate. I hope this advice
helps. Later Dave the Wave
L
Larry & Nancy Solheim
Having been the "butt" of your communications before, Mr. Wave, please know that this is truly appreciated and accepted in the unselfish and giving manner it is offered. I'll be pounding harder today; with a bigger hammer. (It's always good to put my enginering training to use) Much Amphi Love! --Larry
David Derer <dmd@essex1.com> wrote: <blockquote class="replbq" style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid"><tt>Larry perhaps You need to sit on it and rotate. I hope this advice
</tt>
<div style="WIDTH: 500px; COLOR: #909090; TEXT-ALIGN: center"> <hr style="WIDTH: 500px; BORDER-BOTTOM: 1px; TEXT-ALIGN: left"> <tt>YAHOO! GROUPS LINKS</tt>
<ul><tt> <li type="square">Visit your group "amphicar-lovers" on the web.
</tt> <tt> <li type="square">To unsubscribe from this group, send an email to:
</tt> <tt> <li type="square">Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.</tt> [/list]
<!-- |**|end egp html
banner|**| --></blockquote>
<hr size="1">
What are the most popular cars? Find out at Yahoo! Autos
SNOWBIRD Prop housing units General Amphicar Discussion 6
Jon March im=a looking for a spare prop General Amphicar Discussion 1
D Prop rpm General Amphicar Discussion 0
scottamphi Prop Key Size General Amphicar Discussion 3
S Re hood and prop rod General Amphicar Discussion 0
A Prop U Joints on EBay General Amphicar Discussion 0
C Prop driveshaft u-joints sloppy? General Amphicar Discussion 6
amphigill prop rpm General Amphicar Discussion 2
CapnJohn Catastrophic prop failure (new props) General Amphicar Discussion 14
Midwest Amphicar prop shield newly made and installed General Amphicar Discussion 7
T Prop shaft questions please General Amphicar Discussion 11
L Decals (was Re: Noisy Prop Shaft Tubes) General Amphicar Discussion 2
L Noisy Prop Shaft Tubes General Amphicar Discussion 1
T Prop speed General Amphicar Discussion 1
T Prop Cleaning General Amphicar Discussion 6
A Prop Shaft Bearing 3-19-2 Grease General Amphicar Discussion 1
A Space between prop and hull General Amphicar Discussion 2
C Prop shaft torx bolts... General Amphicar Discussion 4
E Inspecting Prop Shaft U-joints General Amphicar Discussion 0
E Directional Stability, was Looking for used prop General Amphicar Discussion 1
S Looking for used prop General Amphicar Discussion 6
D One prop General Amphicar Discussion 0
M prop. General Amphicar Discussion 1
B independent prop drives General Amphicar Discussion 0
M Tool needed @ Celina for prop shaft assembly General Amphicar Discussion 0
M Prop shaft removal clarification needed General Amphicar Discussion 2
G broken prop General Amphicar Discussion 2
A Prop shaft tool General Amphicar Discussion 4
A prop shaft u-joints General Amphicar Discussion 0
T seal puller/prop removal General Amphicar Discussion 0
SNOWBIRD 28MM drive shafts General Amphicar Discussion 3
C Amphicar drive shafts General Amphicar Discussion 3
T My drive shafts are hanging out General Amphicar Discussion 0
S Rear Drive Shafts Resting on Tunnel General Amphicar Discussion 2
T Drive Shafts General Amphicar Discussion 10
