Prop driveshaft u-joints sloppy?
Hi all, I have had my Amphi in the water just a couple times and noticed that my propellor drive shaft U-joints are loose in the shafts. The clips are in place and seated as they should be, but if you grab the shaft and pull, the shaft moves side to side. This looseness is on both shafts and all 4 joints! They are new parts from GI # 3-19-22kit. Has anyone else had this problem???:032:
CapnJohn
Simply, If there is any slop in there as described, the u-joints are bad. They (u-joints) are off the shelf very available parts.
Midwest Amphicar
The original snap rings are a bit thicker. The replacements are not exactly right. You may need to have thin round shims made. A job for Tony. Have him make extras for re sale.
It's always a good idea to save the old snap rings when changing out from original u-joints. Various thicknesses of these clips are sometimes available in the aftermarket but often the originals are a bit thicker than what you can easily find. I once bent round spacers from thin music wire (available from hobby shops) and snapped them in outside the snap rings to give them extra thickness. Do the spacers on all 4 end caps to keep the u-joint centered.
Ken Chambers
U-joint cups should be an interference (press) fit in the yokes so the cups cannot move or rotate at all within the bore. If the cups are loose the yoke needs repair. I recently repaired a driveshaft yoke with a loose U-joint employing a neat trick to reduce the yoke ID.
Here's the procedure. Use a battery charger to deposit (weld) tiny spots of metal on the inside of the yoke bores. I used an older style 12 volt charger containing a traditional heavy transformer. Clamp a thin steel wire, nail, oxy welding rod, etc. in some locking pliers and attach a lead to the pliers. Ground the yoke and start touching the rod to the inside of the yoke bore. Spark, spark, spark, many many times until hundreds or even thousands of little tiny pits of metal are deposited. Careful, the wire gets hot. A couple times per second will add up quickly. The result was a very tight press fit cup into the formerly loose bore.
Additionally, when a U-joint is properly installed the cups should fit snugly up against both snap rings so the joint is centered in the yoke. If the joint cups are slightly too wide, thinner snap rings may need to be used. If the joint is too narrow, washer type shims can be placed against the cups.
SNOWBIRD Prop housing units General Amphicar Discussion 6
Jon March im=a looking for a spare prop General Amphicar Discussion 1
D Prop rpm General Amphicar Discussion 0
scottamphi Prop Key Size General Amphicar Discussion 3
S Re hood and prop rod General Amphicar Discussion 0
A Prop U Joints on EBay General Amphicar Discussion 0
amphigill prop rpm General Amphicar Discussion 2
CapnJohn Catastrophic prop failure (new props) General Amphicar Discussion 14
Midwest Amphicar prop shield newly made and installed General Amphicar Discussion 7
T Prop shaft questions please General Amphicar Discussion 11
L Decals (was Re: Noisy Prop Shaft Tubes) General Amphicar Discussion 2
L Noisy Prop Shaft Tubes General Amphicar Discussion 1
T Prop speed General Amphicar Discussion 1
T Prop Cleaning General Amphicar Discussion 6
A Prop Shaft Bearing 3-19-2 Grease General Amphicar Discussion 1
A Space between prop and hull General Amphicar Discussion 2
C Prop shaft torx bolts... General Amphicar Discussion 4
E Inspecting Prop Shaft U-joints General Amphicar Discussion 0
G prop shafts General Amphicar Discussion 4
E Directional Stability, was Looking for used prop General Amphicar Discussion 1
S Looking for used prop General Amphicar Discussion 6
D One prop General Amphicar Discussion 0
M prop. General Amphicar Discussion 1
B independent prop drives General Amphicar Discussion 0
M Tool needed @ Celina for prop shaft assembly General Amphicar Discussion 0
M Prop shaft removal clarification needed General Amphicar Discussion 2
G broken prop General Amphicar Discussion 2
A Prop shaft tool General Amphicar Discussion 4
A prop shaft u-joints General Amphicar Discussion 0
T seal puller/prop removal General Amphicar Discussion 0
Jon March when driveshaft seal-areas corrode General Amphicar Discussion 18
SNOWBIRD 24mm u joints General Amphicar Discussion 3
F U Joints General Amphicar Discussion 0
Canadian four amphs U Joints General Amphicar Discussion 0
W Drive Shaft U joints General Amphicar Discussion 2
T Axle u-joints General Amphicar Discussion 3
G U Joints! General Amphicar Discussion 3
G U Joints. General Amphicar Discussion 0
D 30mm x 81.8 u-joints General Amphicar Discussion 0
B Oil Change Joints General Amphicar Discussion 0
