Re: Re: Power brake booster
Cap'n:
Just as a followup on Bo's posting below, for a knowledgeable source and
online catalogs on all manner of Triumph cars, you might visit
http://www.rimmerbros.co.uk/ . While I was unable to find any reference to
vacuum assisted or "servo" brake systems for Heralds as such in their online
catalog, there are such Lockheed servo units available for other other
Triumph models such as the Dolomite and Spitfire. Perhaps you could drop
them a line for their advice on the matter.
Before you make any such modifications however, please be advised that I
have encountered warnings here and there on the 'net against fitting such
brake servo mechanisms to twin-leading shoe type drum brake systems such as:
"...A servo should not be added to cars with front drums as it may cause
snatching of the brakes due to the self-servo action of twin leading shoe
type front drums." found at
http://website.lineone.net/~angela-iwnet/triumph/FAQ.html . Whether or not
such warnings come from authoritative sources or apply to the Amphicar I
will leave you to determine, but I thought you should be made aware of them.
Given your work in the field of vehicular hand controls for the disabled,
one might assume that you could be familiar with the similar efforts in
vacuum controls of Les Schofield. In the event that you hadn't, please see
http://www.abovekneeamputee.com/news/driving.html . If nothing else, the
article offers plenty of contact information for Mr. Schofield's and other
mobility systems suppliers.
See you at Celina!
~Bilgey~
Sent: Thursday, September 26, 2002 5:28 AM
Subject: SV: [amphicar-lovers] Re: Power brake booster
Ref: Power brake booster.
Hello John.
On some of the Triumph Heralds there was a vacuum power brake unit installed
as an option, also together with 1197 engines.
The unit was mounted separately from the master-cylinder and it was a very
"neat" unit.
I don't know if the Herald was sold in the US, if not there are probably
some other British oldies that had the same unit.
Best regards
Bo
Sweden
Fr?n: Cap'n John [mailto:minnow@amphicar.net]
Skickat: den 25 september 2002 15:17
?mne: [amphicar-lovers] Re: Power brake booster
> What is your clutch master cylinder from originally?
> Tim w
I believe that it fits late 70s vintage International. The master I
am using is for a clutch and not the brakes.
The problems that I need to contend with are the physical size of the
can (booster) and the vacuum needed to operate it (large can, more
vacuum). I will use an accumulator to store vacuum, but as you know,
room is a concern.
I am hopeing that the 1147 engine will be able to provide enough
vacuum along with the accumulator to make my evil plan work. Mooo bwa
ha ha ha!!
