Pole light door seals
  • Thread starter jlambertspc@aol.com
  • Start date
jlambertspc@aol.com
In a message dated 1/29/2004 10:11:02 AM Eastern Standard Time,
dmd@essex1.com writes:
Atwood has economy priced pole light. 1/2 inch diameter aluminum tubeing
fits inside pole and then fits original engine cover hole. You then can
have a pole as tall and as long as you ever wanted. All for under 20
bucks. Door seals if anyone has that glue on from Hugh. Check it. Some
of that stuff needs a rubber primer and the glue does not stick. One rub
and seal easily peels off. Later Dave the Wave
Where can you get the various rubber gaskets for door handles, hood light,
lenses, and all body mounted items? Does anyone has a source, or lead on what
materials to use for making your own.
Also, the floor mat material so I can cut my own from the existing mat used
as a template. This appears to be a ribbed rubber mat that I have seen in
numerous applications, but am not sure where to purchase. Maybe an auto
upholstery shop? Any thoughts?
Cruiserdog 64 "Dreamin"
Dave Derer
rogtwo@aol.com
Cruiserdog,
Most if not all the seals you list are molded rubber seals. If you want
replacements that look original, I think that Gordon Imports is your only
choice.
Molding rubber parts requires a significant investment in tooling, thus I
think it's unlikely (but not impossible) that anyone is competing with Gordon
Imports on these parts.
However, you could make functional (but not stock looking) seals for many of
these applications by cutting them yourself from flat rubber or dense
closed-cell foam sheets. Auto parts stores and good hardware stores usually
sell flat
rubber sheets for making your own gaskets. If you find a good store, they
will even have different colors to choose from (like black, white, and gray).
For the above-the-waterline seals you mention, is really just a matter of
your sense of aesthetics. Search around your local stores and pick a material
that looks good to you. However, when it comes to a few of the critical seals
(like the rear drive shaft housing boots and the steering box water seal) you
are probably best off buying proven seals. If you loose one of these seals,
you're sinking in a hurry!
Roger
White '63
Seattle
In a message dated 1/29/04 12:15:25 PM Pacific Standard Time,
jlambertspc@aol.com writes:
what
Akamphi Pole light General Amphicar Discussion 2
LNZCRFT Light Pole Internal Thread Size General Amphicar Discussion 1
T Light bulb for pole light for Dolores General Amphicar Discussion 13
C Nav light pole mounts General Amphicar Discussion 2
L Marine Pole Light Blowing Fuses General Amphicar Discussion 3
C Rear pole light General Amphicar Discussion 0
A Light pole socket repairs General Amphicar Discussion 1
M Orignial Black Pole light Sockets General Amphicar Discussion 0
D Light Pole General Amphicar Discussion 2
M Pole light help needed General Amphicar Discussion 0
R Back up light switch General Amphicar Discussion 4
azpaul50 Tail/Marker Light Differences General Amphicar Discussion 0
Akamphi Backup light gaskets General Amphicar Discussion 1
B Bow Light Paint General Amphicar Discussion 11
B Marine light General Amphicar Discussion 6
C Wiper/Marine light dash switch placement ques. General Amphicar Discussion 1
C Bow light General Amphicar Discussion 6
B A NEW Amphi has seen the light of day!! General Amphicar Discussion 3
C New Member Intro "Cruiserdog" - Questions - Navigation Light Source General Amphicar Discussion 3
D nav light river cruise fifth swim General Amphicar Discussion 1
F Nav light General Amphicar Discussion 6
L "Foggy" Parking Light Lenses General Amphicar Discussion 2
B Darkness and Light General Amphicar Discussion 0
A Head light Ground General Amphicar Discussion 2
B Top light installation questions General Amphicar Discussion 1
M Marine Light General Amphicar Discussion 6
D light on Erics car General Amphicar Discussion 0
P Missing Marine Light General Amphicar Discussion 10
A Head light trim needed General Amphicar Discussion 2
D Light on dashboard bilge pump switch General Amphicar Discussion 1
B door seal test Restorations in progress 1
MAE Right Side Door Needed General Amphicar Discussion 0
R door panel springs General Amphicar Discussion 3
B Door glass pattern needed General Amphicar Discussion 3
Akamphi Windshield and door handle instal General Amphicar Discussion 1
T Amphicar door installation General Amphicar Discussion 6
T Door Mounting Question General Amphicar Discussion 1
T Door Seal Question? General Amphicar Discussion 5
A Door County Maritime Museum Boat Show General Amphicar Discussion 0
C Door hinge General Amphicar Discussion 1
G door seal update General Amphicar Discussion 5
G door seals and vapor lock General Amphicar Discussion 0
A Vent frames and door handles needed General Amphicar Discussion 2
F water door lock General Amphicar Discussion 0
L Door Glass 11-36-24 General Amphicar Discussion 0
S Door Skins General Amphicar Discussion 1
