rdboggie@comcast.net
<table>
I jacked up the rear and grabbed the tire. No play in the swing arm assembly, but I found that the whole rear wheel assembly had about 1/4 inch play; not rotational play, but play when I pushed/pulled on the front and back of the tire. I checked the axle nut, which was tight. Do I have wheel bearing problems?
Randy
I only notice it when I take off, but I'll have to pay more attention with the other conditions. I'm doing the swing arm/pinch bolt test tonight.
From the feedback I've received, it could be:
-swing arm/pinch bolts worn or loose
-u-joints
-loose backing plate
-sticking brakes
-mushy engine mounts causing the axle to hit the housing.
thanks,
Randy
> A bit more information would be helpful. Does it
> happen every time? More or less w/ a "hard" clutch
> engagement? Worse if you back up, stop, & then go
> forward?
> 1st though would be a U-joint, but brake shoes that
> "stick" then break-free as power is applied is also a
> possibility. Or even a bad axle bearing, but you
> would most likely hear noise if you jack up the rear
> and spin the tire by hand. While you have the rear
> off the ground, also hold the tire at 9 & 3 o'clock &
> push/pull to check the attachment at the pinchbolt
> swing arm attachment.
> Good luck,
> --Larry
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail - You care about security. So do we.
> http://promotions.yahoo.com/new_mail
> THE AMPHICAR-LOVERS LIST
> Archives:
> visit:
> amphicar770@yahoo.com
> When insuring your Amphicar do not settle for anything less than the very best
> coverage available. Visit Hagerty Collector Car Insurance today at
> http://www.hagerty.com
> Yahoo! Groups Links
> <*> To visit your group on the web, go to:
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
> </blockquote>
<tt>THE AMPHICAR-LOVERS LIST
When insuring your Amphicar do not settle for anything less than the very best coverage available. Visit Hagerty Collector Car Insurance today at
</tt>
</blockquote>
Randy
-u-joints
-sticking brakes
thanks,
Randy
> forward?
> Good luck,
> --Larry
> Do you Yahoo!?
> Archives:
> visit:
> Yahoo! Groups Links
> </blockquote>
</tt>
</blockquote>
