Paper Carb Gasket
P
pfgbrian@aol.com
I just rebult my car last night. it now runs perfect. The order that I used
was like yours, except I had a gasket between every piece. Thats how it came
apart, and how I put it back together.
Manifold/gasket/plastic riser plate/gasket/metal linkage plate/gasket/carb
Brian in CA
By the way, the rebuild kit from Gordons worked perfect-but only comes with
two gaskets
P
pfgbrian@aol.com
That should say rebuilt my carb last night. I wish I could type better.
Brian in CA or
Swimn64
chris_skeeles
I just replaced all the gaskets in my carb because of a gas leak
when the engine gets hot. It seems the manifold neck to the carb
seeps fuel when warm.
My question to the group is, what is the proper "stacking" order for
the paper carb gaskets and the plastic riser plate?
Here is how I have it now:
Manifold - paper - Plastic Riser Plate - Metal linkage plate -
paper - Carb
I guess my confusion is with the linkage plate, is it in between
the paper sandwich or not?
Chris - Red 63
R !5th Annual Mt. Dora Swim-In makes the Orlando Sentinel paper General Amphicar Discussion 3
T An article about amphicars in today's paper with picture! General Amphicar Discussion 0
D Kansas City Paper Ozark write up. General Amphicar Discussion 1
A Last call for Paper Model Photos General Amphicar Discussion 0
A Paper Model Contest General Amphicar Discussion 0
A Paper Amphi Model Magic General Amphicar Discussion 1
M Paper Amphi General Amphicar Discussion 1
R My picture in Paper General Amphicar Discussion 0
A Article from Seattle paper General Amphicar Discussion 1
Midwest Amphicar Carb or ? help General Amphicar Discussion 5
Jon March Carb kit - any pointers? General Amphicar Discussion 5
mike_israel Weber Carb on an Amphi General Amphicar Discussion 8
A Solex Carb Manual on-line General Amphicar Discussion 3
K Carb problem General Amphicar Discussion 0
L Clutch and carb question General Amphicar Discussion 2
M Carb Special General Amphicar Discussion 0
A SU- Carb General Amphicar Discussion 2
L Hot Carb General Amphicar Discussion 3
E Amphi Carb Rebuild Kits on eBay General Amphicar Discussion 0
L Carb Rebuild General Amphicar Discussion 0
M Carb Update General Amphicar Discussion 0
D Carb Things To Remember General Amphicar Discussion 1
K Carb Line General Amphicar Discussion 0
K Carb fuel line General Amphicar Discussion 0
C Carb gasket Part # General Amphicar Discussion 0
C Carb tuning General Amphicar Discussion 1
D Heat shield: Carb General Amphicar Discussion 0
K Solex carb main fuel jet General Amphicar Discussion 2
P Carb rebuild experience General Amphicar Discussion 1
D carb General Amphicar Discussion 0
D Dripping gas from the Carb General Amphicar Discussion 1
S Engine gasket sets General Amphicar Discussion 1
N gasket?? General Amphicar Discussion 8
P Oil Pan Gasket General Amphicar Discussion 4
