Original fuel tap
In case anyone is interested, I just got a notice from Shelley at Gordon Imports that the original fuel taps are now in stock for 149.99. I must have tried ordering one back in 2013 and was put on a back order list!
Amphicar Forum Admin
Staff member
Make sure to update your fuel line while you are at it. Only use the latest fuel hose, which will be rated SAE 30R9, This is a lined hose (Lined with a Teflon like material) and is the stuff made to resist today's oxygenated gasolines. The old 30R7 hose USED to be acceptable, but no longer is, it will rot out from many of today's nasty fuels.
Many vendors still sell what they call the "correct German, metric hose", BUT it is often the inferior type, despite being OEM style factory hose. If it does not have the teflon like inner liner that 30R9 has, it is no good. Don't risk a leak or a fire. The old braided stuff was designed for another era of fuel.
You can buy 30R9 hose at many parts stores, make sure 30R9 is printed on the hose. It is difficult to find metric 30R9, I use 5/16 inch and 3/8 inch diameter 30R9 with the correct fuel-injection type hose clamps and find that it holds fine, nice and tight.
6 Ready to sell a 1967 All Original Red any advise? General Amphicar Discussion 2
Jon March Original prototype General Amphicar Discussion 0
W Original Maintenance Manual Model 770 and Owners Manual General Amphicar Discussion 3
Jon March About the original bilge pump... General Amphicar Discussion 23
Andreas Gomoll Original rims .... General Amphicar Discussion 1
Jon March poll: original bilge pump mounting & depth gauge General Amphicar Discussion 1
Bilgemaster Original Amphi Key No. 5415? General Amphicar Discussion 13
C WANTED, Pr of old original propellors General Amphicar Discussion 0
Cameron in UK NOS Original Amphicar wiper blades available. General Amphicar Discussion 5
Midwest Amphicar Restored or un restored-original You be judge General Amphicar Discussion 12
jfriese Original Battery Box Photos General Amphicar Discussion 0
mike_israel Wow! An Original Aerocar For Sale General Amphicar Discussion 6
J Original Amphicar Horns General Amphicar Discussion 0
R Original Horn Help? General Amphicar Discussion 2
C Resto guidlines/Original Amphicars General Amphicar Discussion 7
R original red General Amphicar Discussion 0
R original red touch-u0 General Amphicar Discussion 0
A Original Hitch placement General Amphicar Discussion 0
A Original pump alternative General Amphicar Discussion 0
T read this Original pump alternative General Amphicar Discussion 1
T So you like the look of your original bilge pump... General Amphicar Discussion 2
M Original Amphicar Radio General Amphicar Discussion 2
C Colors and an original spare tire trade General Amphicar Discussion 0
R original colours General Amphicar Discussion 3
J Original Parts Manuals General Amphicar Discussion 0
