Oil Pan Gasket
  • Thread starter Thread starter pedlcar@webtv.net
P
pedlcar@webtv.net
I have a 1966 Amphicar I'am restoring-- I need a oil pan gasket or I
will have to make one- any help? John
John:
You should be able to order one up from Gordons or any good auto parts
store. I don't think it's unique to the 1147cc Triumph but I could be
wrong.
To: <amphicar-lovers@egroups.com>
Sent: Saturday, September 23, 2000 2:01 PM
Subject: [amphicar-lovers] Oil Pan Gasket
Mike's right, the gasket (but not the actual pan) is common to all 1147/1300
and I think even 1500 engines.
Some tips with this:
Check carefully the bottom of the pan (for reference its called the sump in
the UK) for holes, in Amphicar they can rot through if water has been left
in the bilge, look for pitting on the outside.
Look at the brazing around the plug, if it been overtightened by an "animal"
in the past it can be cracked.
Put a straight edge across the top of the pan and use a hammer and dolly (I
wonder if you have a different name for it !) to true up any flat spots, the
base of the block is completely flat, check especially the area around each
bolt, if it's bad you can find high spots by tapeing some wet and dry to a
sheet of glass and rubbing the top of the pan on it. If it's never been off
before it'll probably be OK...but....
Finally DON'T OVERTIGHTEN THE BOLTS they should only be about 15lbs of
torque, which doesn't feel tight enough but any tighter and the area around
the bolt will dish and the thing will leak, if worried put Locktite on the
threads.
David Chapman in the UK.
Is Hugh Gordon out of oil pan gaskets? If so, and if you can hold on for a
couple-few weeks, I should have a Herald Engine Parts Catalog arriving from
England by then. Drop me a line in, say, early November if nothing's panned
out for you by then, and I'll take a look see.
~Bilgemaster~
I recently purchased upper and lower gasket kits from NAPA. After having to
remove the pan (to do it right the second time), they were able to order the
pan gasket only, about $5.32.
Good Luck,
--LarryS
Sent: Saturday, September 23, 2000 9:38 PM
Subject: Re: [amphicar-lovers] Oil Pan Gasket
a
from
panned
> ~Bilgemaster~
S
Replies
1
Views
865
wick68355@aol.com
N
Replies
8
Views
2K
WB6WSN
Replies
Views
771
Craig Taylor
P
Replies
2
Views
921
chris_skeeles
