Oil change made easy
Amphicar Forum Admin
Staff member
Changed Amphi's oil this weekend. Don't ask what brand or type of oil I used, I do not want to start any wars.
I do hate changing the oil on Amphi so this time I took a different approach, I used my fluid extractor. Inserted tube down dipstick and about 7 minutes later was done.
Mityvac 07400
and a tube threw bilge hole, no Oil in bilge.! Nice to have a Hoist! It is important to get every bit of oil out and bottom of pans are usually covered in sludge unless you have taken the pan off and cleaned it.
Staff member
Several newer vehicles no longer even have drain plugs and the change is done using an extractor. of course those vehicles have more modern engines which run much cleaner than our Amphi tractor motors!
I do agree that removing the drain plug is more likely to clear out anything lurking at the bottom of the oil pan. For me, my engine was rebuilt and my oil always comes out very clean so I will probably only remove the plug every 3rd change or so. I have not tried it with the transmission yet but that is my next job.
DougFromBaltimore
I had an Italian car that used O7IO, at least that's what the cap said when it was upside down ;). I used to get that question at car shows....
mike_israel Name change for forums? General Amphicar Discussion 4
sdreich 12th Annual San Diego Swim In August 18,2012 (Venue Change) General Amphicar Discussion 2
mike_israel Petition to Change 25 Year Import Rule to 15 General Amphicar Discussion 0
Jacques B. Oil change based on Hours General Amphicar Discussion 7
W Fwd: OIL CHANGE INSTRUCTIONS General Amphicar Discussion 0
R color change General Amphicar Discussion 4
B Oil Change Joints General Amphicar Discussion 0
S Questions about oil change and replacement upholstry... General Amphicar Discussion 2
D Junk Yard Wars Date Change To April 23 General Amphicar Discussion 1
A Change of hotels General Amphicar Discussion 0
D SWIM IN CHANGE- Directions General Amphicar Discussion 1
D Location Change for Swim with Dave General Amphicar Discussion 4
A VIRUS WARNING! (A real one for a change) General Amphicar Discussion 1
M Amsoil change intervals General Amphicar Discussion 1
A Design Change for Transmission Shift Linkage? General Amphicar Discussion 0
M Amphistock location change General Amphicar Discussion 3
B Hour Meters from J.C. Whitney & Oil Change Intervals General Amphicar Discussion 0
C The more things change... General Amphicar Discussion 0
L Email Address Change General Amphicar Discussion 2
A Nashville Shores Swim date change General Amphicar Discussion 0
M oil change General Amphicar Discussion 0
E New propellers and nuts made of aluminum General Amphicar Discussion 19
azpaul50 Home-made Amphi in Calexico, CA General Amphicar Discussion 2
Jacques B. National Geografic man made amphicar tires General Amphicar Discussion 0
A We made CNN!!! General Amphicar Discussion 2
Midwest Amphicar prop shield newly made and installed General Amphicar Discussion 7
D US made Aquada lookalike General Amphicar Discussion 5
T Custom made Mermaid Tails General Amphicar Discussion 1
M Brake Bleeding Made Easy! General Amphicar Discussion 0
D Half Safe made me do it General Amphicar Discussion 0
C I made another SS for everyone General Amphicar Discussion 0
R Made reservations-Celing General Amphicar Discussion 1
J Parts made in Sweden? & Bond Amphi General Amphicar Discussion 0
