CapnJohn
For the 1st time in 8 years I have an electrical issue in my white Amphi. When restoring the car I paid particular attention to the harness and proper grounds. It has paid off so far.
It is (-) neg ground, alternator car w/Pertronix ign system and coil.
I am getting high voltage back thru the (-) neg terminal and thru the original wiring. When a test light is attached to the (-) terminal on the coil it blinks rapidly while trying to kill the engine. If I rev it a bit it won't die. I have replaced the coil and pertronix unit, but still I get this high voltage backfeed? I have not measured the actual voltage other than with my calibrated fingers. It's NOT 12V as expected, that's for sure!
What could be causing this??? Possesed by the drunken spirit of Joseph Lucas himself?
